Bootloop to Bootloader after locking bootloader
I have a big problem.
Can anyone help me?
I have flashed iodé according to the instructions. Then I accidentally deactivated OEM Unlock in the settings. So I activated the blocking. Now I wanted to lock the bootloader again so that the message does not always appear when booting. Now my FP5 always boots directly into the bootloader but I can no longer flash the Stockrom because flashing is locked and since I can no longer get into iodé I cannot activate the OEM Unlock.
flastboot flashing unlock does not work
Is there still a possibility for me to flash a ROM or to unlock the bootloader?
Best regards,
Matthäus
Will it let you boot into recovery, whether from bootloader or using the button combo? If so, you should be able to factory reset and/or sideload an iode OTA.
No. I can’t boot into recovery.
you have to contact Fairphone support and send it to their repair center.
Thank you very much.
I have contacted support and am now waiting to hear back.
If you want to speed that up, give them a call.
