Hello together!
I know you have read about this problem a hundert times, but i can not find the solution.
I knwo my fairphone for a while know and ive installed FPopenOS and diffrent thinks, so I thaught i woud be able to fix this on my own. BUT:
The Fairphone remains in Bootloops and they are only 5-7 secons long so there is absolulty no posibillity to start TWRP or connect it any PC to intall in manually.
I can not find any advise and i need your help,
For Info: I havent yoused the FP2 for now roundabout 7 months, so that may be a part of the problem.
Thank you, that solved my issue. The battery was to low!
And now i understand the main problem of my FP2, the reason, why i stopped sousing it: The battery is just not fitting well into the Body. Now i will contact the support for help!
