Thanks for your help.I hope we can find a solution. Well, I’m going to bed. I’ve had a tough day today.Good night, see you tomorrow.
Good night ![]()
You’re basically there, until you reboot the phone you have root now, the su -c etc. command should work now.
This whole situation should be solvable tomorrow ![]()
I started from scratch. Here’s what I did:
1/ I uninstalled Magisk downloaded yesterday from FDroid and downloaded Magisk-v29.0.apk from GitHub: Release Magisk v29.0 · topjohnwu/Magisk · GitHub
2/ I transferred boot.img from the Fairphone installation package (FP4.QREL.15.14.3.20250923075848.user-factory) to the phone.
3/ I launched Magisk, patched the boot.img and transferred the magisk_patched-29000_sZcK0.img file to the PC.
4/ I booted on the patched image:
lool@lool-P52:~/Bureau/boot_patch$ adb reboot bootloader
total 98304
-rw-r--r-- 1 lool lool 100663296 nov. 15 14:07 magisk_patched-29000_sZcK0.img
lool@lool-P52:~/Bureau/boot_patch$ fastboot boot magisk_patched-29000_sZcK0.img
Sending 'boot.img' (98304 KB) OKAY [ 0.798s]
Booting OKAY [ 10.158s]
Finished. Total time: 11.158s
5/ Once the phone had restarted, I ran the following commands:
lool@lool-P52:~/Bureau/boot_patch$ adb shell su -c 'resetprop ro.boot.flash.locked 1'
Permission denied
Permission denied
6/ I retrieved the Magisk logs (I can provide the complete log if needed (1191 lines):
---Magisk Logs---
29.0 (29000)
01-06 17:27:50.952 867 867 I : Magisk 29.0(29000) daemon started
01-06 17:27:50.954 867 867 I : * Device API level: 35
01-06 17:27:50.963 867 869 I : ** post-fs-data mode running
01-06 17:27:50.985 867 869 I : * Initializing Magisk environment
01-06 17:27:51.166 867 869 I : * Running post-fs-data.d scripts
01-06 17:27:51.167 867 869 I : * Running module post-fs-data scripts
01-06 17:27:51.167 867 869 I : * Loading modules
11-15 14:09:12.572 867 869 I : ** late_start service mode running
11-15 14:09:12.572 867 869 I : * Running service.d scripts
11-15 14:09:12.572 867 869 I : * Running module service scripts
11-15 14:09:20.988 867 869 I : ** boot-complete triggered
11-15 14:09:20.994 867 869 I : * Found preinit dir: /metadata/watchdog/magisk
11-15 14:11:42.795 867 6861 W : su: request rejected (2000)
11-15 14:12:13.280 867 6861 W : su: request rejected (2000)
It therefore appears that the su command is not accepted.
For your information, here is the result of getprop:
lool@lool-P52:~/Bureau/boot_patch$ adb shell getprop
[DEVICE_PROVISIONED]: [1]
[aaudio.hw_burst_min_usec]: [2000]
[aaudio.mmap_exclusive_policy]: [2]
[aaudio.mmap_policy]: [2]
[af.fast_track_multiplier]: [1]
[apex.all.ready]: [true]
[arm64.memtag.process.system_server]: [off]
[audio.deep_buffer.media]: [true]
[audio.offload.min.duration.secs]: [30]
[audio.offload.video]: [true]
[audio.sys.mute.latency.factor]: [2]
[audio.sys.noisy.broadcast.delay]: [500]
[audio.sys.offload.pstimeout.secs]: [3]
[audio.sys.routing.latency]: [0]
[bluetooth.device.class_of_device]: [90,2,12]
[bluetooth.device.default_name]: [Fairphone 4 5G]
[bluetooth.profile.a2dp.source.enabled]: [true]
[bluetooth.profile.asha.central.enabled]: [true]
[bluetooth.profile.avrcp.controller.enabled]: [true]
[bluetooth.profile.avrcp.target.enabled]: [true]
[bluetooth.profile.bas.client.enabled]: [true]
[bluetooth.profile.gatt.enabled]: [true]
[bluetooth.profile.hfp.ag.enabled]: [true]
[bluetooth.profile.hid.device.enabled]: [true]
[bluetooth.profile.hid.host.enabled]: [true]
[bluetooth.profile.map.server.enabled]: [true]
[bluetooth.profile.opp.enabled]: [true]
[bluetooth.profile.pan.nap.enabled]: [true]
[bluetooth.profile.pan.panu.enabled]: [true]
[bluetooth.profile.pbap.server.enabled]: [true]
[bluetooth.profile.sap.server.enabled]: [true]
[bootreceiver.enable]: [0]
[build.version.extensions.ad_services]: [19]
[build.version.extensions.r]: [19]
[build.version.extensions.s]: [19]
[build.version.extensions.t]: [19]
[build.version.extensions.u]: [19]
[build.version.extensions.v]: [19]
[cache_key.bluetooth.bluetooth_adapter_get_connection_state]: [-3298736849631415443]
[cache_key.bluetooth.bluetooth_adapter_get_profile_connection_state]: [-3298736849631415442]
[cache_key.bluetooth.bluetooth_adapter_get_state]: [-3298736849631415441]
[cache_key.bluetooth.bluetooth_adapter_is_offloaded_filtering_supported]: [-3298736849631415448]
[cache_key.bluetooth.bluetooth_device_get_bond_state]: [-3298736849631415451]
[cache_key.bluetooth.bluetooth_map_get_connection_state]: [-3298736849631415445]
[cache_key.bluetooth.bluetooth_sap_get_connection_state]: [-3298736849631415444]
[cache_key.display_info]: [6203091013252320632]
[cache_key.get_packages_for_uid]: [6203091013252320612]
[cache_key.has_system_feature]: [6203091013252320349]
[cache_key.is_compat_change_enabled]: [6203091013252320581]
[cache_key.is_interactive]: [6203091013252320628]
[cache_key.is_power_save_mode]: [6203091013252320605]
[cache_key.is_user_unlocked]: [6203091013252320400]
[cache_key.location_enabled]: [6203091013252320364]
[cache_key.package_info]: [6203091013252320587]
[cache_key.system_server.account_user_data]: [6203091013252320601]
[cache_key.system_server.accounts_data]: [6203091013252320421]
[cache_key.system_server.connectionless_stylus_handwriting]: [6203091013252320403]
[cache_key.system_server.device_policy_manager_caches]: [6203091013252320362]
[cache_key.system_server.get_credential_type]: [6203091013252320365]
[cache_key.system_server.get_night_mode]: [6203091013252320360]
[cache_key.system_server.stylus_handwriting]: [6203091013252320402]
[cache_key.telephony.phone_account_to_subid]: [4370188839361591108]
[cache_key.telephony.subscription_manager_service]: [4370188839361591104]
[config.disable_rtt]: [true]
[dalvik.vm.appimageformat]: [lz4]
[dalvik.vm.dex2oat-Xms]: [64m]
[dalvik.vm.dex2oat-Xmx]: [512m]
[dalvik.vm.dex2oat-max-image-block-size]: [524288]
[dalvik.vm.dex2oat-minidebuginfo]: [true]
[dalvik.vm.dex2oat-resolve-startup-strings]: [true]
[dalvik.vm.dex2oat64.enabled]: [true]
[dalvik.vm.dexopt.secondary]: [true]
[dalvik.vm.dexopt.thermal-cutoff]: [2]
[dalvik.vm.enable_pr_dexopt]: [true]
[dalvik.vm.heapgrowthlimit]: [256m]
[dalvik.vm.heapmaxfree]: [32m]
[dalvik.vm.heapminfree]: [8m]
[dalvik.vm.heapsize]: [512m]
[dalvik.vm.heapstartsize]: [16m]
[dalvik.vm.heaptargetutilization]: [0.5]
[dalvik.vm.image-dex2oat-Xms]: [64m]
[dalvik.vm.image-dex2oat-Xmx]: [64m]
[dalvik.vm.isa.arm.features]: [default]
[dalvik.vm.isa.arm.variant]: [cortex-a9]
[dalvik.vm.isa.arm64.features]: [default]
[dalvik.vm.isa.arm64.variant]: [generic]
[dalvik.vm.madvise.artfile.size]: [4294967295]
[dalvik.vm.madvise.odexfile.size]: [104857600]
[dalvik.vm.madvise.vdexfile.size]: [104857600]
[dalvik.vm.minidebuginfo]: [true]
[dalvik.vm.systemuicompilerfilter]: [speed]
[dalvik.vm.usap_pool_enabled]: [false]
[dalvik.vm.usap_pool_refill_delay_ms]: [3000]
[dalvik.vm.usap_pool_size_max]: [3]
[dalvik.vm.usap_pool_size_min]: [1]
[dalvik.vm.usap_refill_threshold]: [1]
[dalvik.vm.useartservice]: [true]
[dalvik.vm.usejit]: [true]
[debug.atrace.tags.enableflags]: [0]
[debug.egl.hw]: [0]
[debug.force_rtl]: [false]
[debug.hwui.skia_atrace_enabled]: [false]
[debug.hwui.skia_tracing_enabled]: [false]
[debug.hwui.skia_use_perfetto_track_events]: [false]
[debug.mdpcomp.logs]: [0]
[debug.perfetto.sdk_sysprop_guard_generation]: [0]
[debug.renderengine.skia_tracing_enabled]: [false]
[debug.renderengine.skia_use_perfetto_track_events]: [false]
[debug.sf.enable_advanced_sf_phase_offset]: [1]
[debug.sf.enable_hwc_vds]: [0]
[debug.sf.high_fps_early_gl_phase_offset_ns]: [-4000000]
[debug.sf.high_fps_early_phase_offset_ns]: [-4000000]
[debug.sf.high_fps_late_app_phase_offset_ns]: [1000000]
[debug.sf.high_fps_late_sf_phase_offset_ns]: [-4000000]
[debug.sf.hw]: [0]
[debug.sf.latch_unsignaled]: [1]
[debug.sf.perf_fps_early_gl_phase_offset_ns]: [-5000000]
[debug.sf.perf_fps_early_phase_offset_ns]: [-5000000]
[debug.sf.perf_fps_late_sf_phase_offset_ns]: [-5000000]
[debug.sf.predict_hwc_composition_strategy]: [0]
[debug.stagefright.ccodec]: [1]
[debug.stagefright.omx_default_rank]: [0]
[debug.tracing.battery_status]: [5]
[debug.tracing.device_state]: [0:DEFAULT]
[debug.tracing.plug_type]: [1]
[debug.tracing.screen_brightness]: [0.0]
[debug.tracing.screen_state]: [1]
[dev.bootcomplete]: [1]
[dev.mnt.blk.data]: [sda11]
[dev.mnt.blk.data.user.0]: [sda11]
[dev.mnt.blk.data_mirror.cur_profiles]: [sda11]
[dev.mnt.blk.data_mirror.data_ce.null]: [sda11]
[dev.mnt.blk.data_mirror.data_ce.null.0]: [sda11]
[dev.mnt.blk.data_mirror.data_de.null]: [sda11]
[dev.mnt.blk.data_mirror.misc_ce.null]: [sda11]
[dev.mnt.blk.data_mirror.misc_de.null]: [sda11]
[dev.mnt.blk.data_mirror.ref_profiles]: [sda11]
[dev.mnt.blk.data_mirror.storage_area]: [sda11]
[dev.mnt.blk.metadata]: [sda7]
[dev.mnt.blk.mnt.vendor.oempersist]: [sda8]
[dev.mnt.blk.mnt.vendor.persist]: [sda3]
[dev.mnt.blk.odm]: [sda10]
[dev.mnt.blk.product]: [sda10]
[dev.mnt.blk.root]: [sda10]
[dev.mnt.blk.system_ext]: [sda10]
[dev.mnt.blk.vendor]: [sda10]
[dev.mnt.blk.vendor.bt_firmware]: [sde7]
[dev.mnt.blk.vendor.dsp]: [sde11]
[dev.mnt.blk.vendor.firmware_mnt]: [sde6]
[dev.mnt.dev.data]: [dm-45]
[dev.mnt.dev.data.user.0]: [dm-45]
[dev.mnt.dev.data_mirror.cur_profiles]: [dm-45]
[dev.mnt.dev.data_mirror.data_ce.null]: [dm-45]
[dev.mnt.dev.data_mirror.data_ce.null.0]: [dm-45]
[dev.mnt.dev.data_mirror.data_de.null]: [dm-45]
[dev.mnt.dev.data_mirror.misc_ce.null]: [dm-45]
[dev.mnt.dev.data_mirror.misc_de.null]: [dm-45]
[dev.mnt.dev.data_mirror.ref_profiles]: [dm-45]
[dev.mnt.dev.data_mirror.storage_area]: [dm-45]
[dev.mnt.dev.metadata]: [sda7]
[dev.mnt.dev.mnt.vendor.oempersist]: [sda8]
[dev.mnt.dev.mnt.vendor.persist]: [sda3]
[dev.mnt.dev.odm]: [dm-9]
[dev.mnt.dev.product]: [dm-7]
[dev.mnt.dev.root]: [dm-5]
[dev.mnt.dev.system_ext]: [dm-6]
[dev.mnt.dev.vendor]: [dm-8]
[dev.mnt.dev.vendor.bt_firmware]: [sde7]
[dev.mnt.dev.vendor.dsp]: [sde11]
[dev.mnt.dev.vendor.firmware_mnt]: [sde6]
[dev.mnt.rootdisk.data]: [sda]
[dev.mnt.rootdisk.data.user.0]: [sda]
[dev.mnt.rootdisk.data_mirror.cur_profiles]: [sda]
[dev.mnt.rootdisk.data_mirror.data_ce.null]: [sda]
[dev.mnt.rootdisk.data_mirror.data_ce.null.0]: [sda]
[dev.mnt.rootdisk.data_mirror.data_de.null]: [sda]
[dev.mnt.rootdisk.data_mirror.misc_ce.null]: [sda]
[dev.mnt.rootdisk.data_mirror.misc_de.null]: [sda]
[dev.mnt.rootdisk.data_mirror.ref_profiles]: [sda]
[dev.mnt.rootdisk.data_mirror.storage_area]: [sda]
[dev.mnt.rootdisk.metadata]: [sda]
[dev.mnt.rootdisk.mnt.vendor.oempersist]: [sda]
[dev.mnt.rootdisk.mnt.vendor.persist]: [sda]
[dev.mnt.rootdisk.odm]: [sda]
[dev.mnt.rootdisk.product]: [sda]
[dev.mnt.rootdisk.root]: [sda]
[dev.mnt.rootdisk.system_ext]: [sda]
[dev.mnt.rootdisk.vendor]: [sda]
[dev.mnt.rootdisk.vendor.bt_firmware]: [sde]
[dev.mnt.rootdisk.vendor.dsp]: [sde]
[dev.mnt.rootdisk.vendor.firmware_mnt]: [sde]
[dev.pm.dyn_samplingrate]: [1]
[gsm.current.phone-type]: [1,1]
[gsm.network.type]: [HSPA,Unknown]
[gsm.operator.alpha]: [,]
[gsm.operator.iso-country]: [fr,]
[gsm.operator.isroaming]: [false,false]
[gsm.operator.numeric]: [,]
[gsm.sim.operator.alpha]: [,]
[gsm.sim.operator.iso-country]: [,]
[gsm.sim.operator.numeric]: [,]
[gsm.sim.state]: [ABSENT,NOT_READY]
[gsm.version.baseband]: [S.HI.2.5.1.c4-00010-BITRA_GEN_PACK-1.121005.3,S.HI.2.5.1.c4-00010-BITRA_GEN_PACK-1.121005.3]
[gsm.version.ril-impl]: [Qualcomm RIL 1.0]
[hwservicemanager.ready]: [true]
[init.svc.aconfigd]: [stopped]
[init.svc.aconfigd-mainline-init]: [stopped]
[init.svc.aconfigd-platform-init]: [stopped]
[init.svc.adbd]: [running]
[init.svc.android.thermal-hal]: [running]
[init.svc.apexd]: [stopped]
[init.svc.apexd-bootstrap]: [stopped]
[init.svc.apexd-snapshotde]: [stopped]
[init.svc.art_boot]: [stopped]
[init.svc.artd]: [stopped]
[init.svc.audioserver]: [running]
[init.svc.automation_adb_setup]: [stopped]
[init.svc.automation_setup]: [stopped]
[init.svc.bootanim]: [stopped]
[init.svc.boringssl_self_test32]: [stopped]
[init.svc.boringssl_self_test32_vendor]: [stopped]
[init.svc.boringssl_self_test64]: [stopped]
[init.svc.boringssl_self_test64_vendor]: [stopped]
[init.svc.boringssl_self_test_apex32]: [stopped]
[init.svc.boringssl_self_test_apex64]: [stopped]
[init.svc.bpfloader]: [stopped]
[init.svc.cameraserver]: [running]
[init.svc.cnss-daemon]: [running]
[init.svc.dcvs-sh]: [stopped]
[init.svc.derive_classpath]: [stopped]
[init.svc.derive_sdk]: [stopped]
[init.svc.display-color-hal-1-0]: [running]
[init.svc.dpmQmiMgr]: [running]
[init.svc.dpmd]: [running]
[init.svc.drm]: [running]
[init.svc.feature_enabler_client]: [running]
[init.svc.gatekeeper-1-0]: [running]
[init.svc.gatekeeperd]: [running]
[init.svc.gnss_service]: [running]
[init.svc.gpu]: [running]
[init.svc.health-hal-2-1]: [running]
[init.svc.heapprofd]: [stopped]
[init.svc.hidl_memory]: [running]
[init.svc.hwservicemanager]: [running]
[init.svc.idmap2d]: [stopped]
[init.svc.incidentd]: [running]
[init.svc.installd]: [running]
[init.svc.iop-hal-2-0]: [running]
[init.svc.irsc_util]: [stopped]
[init.svc.keystore2]: [running]
[init.svc.lmkd]: [running]
[init.svc.loc_launcher]: [running]
[init.svc.logd]: [running]
[init.svc.logd-auditctl]: [stopped]
[init.svc.logd-reinit]: [stopped]
[init.svc.media]: [running]
[init.svc.media.swcodec]: [running]
[init.svc.mediadrm]: [running]
[init.svc.mediaextractor]: [running]
[init.svc.mediametrics]: [running]
[init.svc.misctrl]: [stopped]
[init.svc.mlid]: [running]
[init.svc.netd]: [running]
[init.svc.neuralnetworks_hal_service]: [running]
[init.svc.nfc_hal_service]: [running]
[init.svc.odsign]: [stopped]
[init.svc.pasr-hal-1-0]: [running]
[init.svc.perf-hal-2-2]: [running]
[init.svc.perfetto_persistent_sysui_tracing_for_bugreport]: [stopped]
[init.svc.poweropt-service]: [running]
[init.svc.prng_seeder]: [running]
[init.svc.qccsyshal@1.2-service]: [running]
[init.svc.qccsyshal_aidl-service]: [stopped]
[init.svc.qccvndhalservice]: [running]
[init.svc.qcom-c_core-sh]: [stopped]
[init.svc.qcom-c_main-sh]: [stopped]
[init.svc.qcom-post-boot]: [stopped]
[init.svc.qcom-sh]: [stopped]
[init.svc.qseecom-service]: [running]
[init.svc.qsguard]: [running]
[init.svc.qspmhal]: [running]
[init.svc.qteeconnector-hal-1-0]: [running]
[init.svc.qti-media]: [stopped]
[init.svc.qti_display_boot]: [stopped]
[init.svc.qti_esepowermanager_service_1_1]: [running]
[init.svc.sensorscal-hal-1-0]: [running]
[init.svc.servicemanager]: [running]
[init.svc.smcd]: [running]
[init.svc.soter-1-0]: [running]
[init.svc.ssgqmigd]: [running]
[init.svc.statsd]: [running]
[init.svc.storaged]: [running]
[init.svc.surfaceflinger]: [running]
[init.svc.system_suspend]: [running]
[init.svc.tctd]: [running]
[init.svc.thermal-engine]: [running]
[init.svc.time_daemon]: [running]
[init.svc.tombstoned]: [running]
[init.svc.traced]: [running]
[init.svc.traced_perf]: [stopped]
[init.svc.traced_probes]: [running]
[init.svc.tui_comm-1-0]: [running]
[init.svc.ueventd]: [running]
[init.svc.update_engine]: [running]
[init.svc.update_verifier]: [stopped]
[init.svc.usbd]: [stopped]
[init.svc.vendor-qti-media-c2-hal-1-0]: [running]
[init.svc.vendor-sensor-sh]: [stopped]
[init.svc.vndservicemanager]: [running]
[init.svc.vold]: [running]
[init.svc.wfdhdcphalservice]: [running]
[init.svc.wfdvndservice]: [running]
[init.svc.wificond]: [running]
[init.svc.wifidisplayhalservice]: [running]
[init.svc.wpa_supplicant]: [running]
[init.svc.zygote]: [running]
[init.svc.zygote_secondary]: [running]
[kcmdline.binder]: [c]
[kcmdline.loaded]: [1]
[log.tag.APM_AudioPolicyManager]: [D]
[log.tag.stats_log]: [I]
[logd.ready]: [true]
[masterclear.allow_retain_esim_profiles_after_fdr]: [true]
[media.aac_51_output_enabled]: [true]
[media.settings.xml]: [/vendor/etc/media_profiles_vendor.xml]
[media.stagefright.audio.deep]: [false]
[media.stagefright.enable-aac]: [true]
[media.stagefright.enable-fma2dp]: [true]
[media.stagefright.enable-http]: [true]
[media.stagefright.enable-player]: [true]
[media.stagefright.enable-qcp]: [true]
[media.stagefright.enable-scan]: [true]
[media.stagefright.thumbnail.prefer_hw_codecs]: [true]
[mmp.enable.3g2]: [true]
[net.bt.name]: [Android]
[net.tcp.2g_init_rwnd]: [10]
[nfc.initialized]: [true]
[odsign.key.done]: [1]
[odsign.verification.done]: [1]
[odsign.verification.success]: [1]
[partition.odm.verified]: [2]
[partition.odm.verified.check_at_most_once]: [0]
[partition.odm.verified.hash_alg]: [sha1]
[partition.odm.verified.root_digest]: [87dbc68bf85b33463630c919de00c526b2c36c48]
[partition.product.verified]: [2]
[partition.product.verified.check_at_most_once]: [0]
[partition.product.verified.hash_alg]: [sha256]
[partition.product.verified.root_digest]: [04c9cae3441470c779c428595051c7d42944191b781f47e2059498e8cbd0c9a8]
[partition.system.verified]: [2]
[partition.system.verified.check_at_most_once]: [0]
[partition.system.verified.hash_alg]: [sha256]
[partition.system.verified.root_digest]: [da4cb5a3cf77ffadc3e3e996e7fb011a0c55d1723e5fad4bb794697d705d095b]
[partition.system_ext.verified]: [2]
[partition.system_ext.verified.check_at_most_once]: [0]
[partition.system_ext.verified.hash_alg]: [sha256]
[partition.system_ext.verified.root_digest]: [5597ab2150e9ba05c5af21083f1150f74c83c2b2265c66aaeacbaef479a8ca5a]
[partition.vendor.verified]: [2]
[partition.vendor.verified.check_at_most_once]: [0]
[partition.vendor.verified.hash_alg]: [sha1]
[partition.vendor.verified.root_digest]: [09d67b04df311e5686fc9790d206d569554a3a05]
[persist.backup.ntpServer]: ["0.pool.ntp.org"]
[persist.data.df.agg.dl_pkt]: [10]
[persist.data.df.agg.dl_size]: [4096]
[persist.data.df.dev_name]: [rmnet_usb0]
[persist.data.df.dl_mode]: [5]
[persist.data.df.iwlan_mux]: [9]
[persist.data.df.mux_count]: [8]
[persist.data.df.ul_mode]: [5]
[persist.data.wda.enable]: [true]
[persist.debug.coresight.config]: [stm-events]
[persist.debug.wfd.enable]: [1]
[persist.device_config.aconfig_flags.accessibility.enable_magnifier_thumbnail]: [false]
[persist.device_config.aconfig_flags.activity_manager_native_boot.modern_queue_enabled]: [true]
[persist.device_config.aconfig_flags.bluetooth.INIT_gd_hal_snoop_logger_filtering]: [true]
[persist.device_config.aconfig_flags.bluetooth.INIT_gd_hal_snoop_logger_socket]: [true]
[persist.device_config.aconfig_flags.bluetooth.audio_policy_ag_enabled]: [true]
[persist.device_config.aconfig_flags.bluetooth.audio_policy_hf_enabled]: [true]
[persist.device_config.aconfig_flags.bluetooth.le_audio_enabled_by_default]: [false]
[persist.device_config.aconfig_flags.bluetooth.location_denylist_advertising_data]: [⊈0016AAFE40/00FFFFFFF0,⊆0016AAFE/00FFFFFF,⊆00FF4C0002/00FFFFFFFF]
[persist.device_config.aconfig_flags.bluetooth.location_denylist_mac]: []
[persist.device_config.aconfig_flags.bluetooth.location_denylist_name]: []
[persist.device_config.aconfig_flags.bluetooth.scan_timeout_millis]: [300000]
[persist.device_config.aconfig_flags.companion.enable_context_sync_telecom]: [false]
[persist.device_config.aconfig_flags.configuration.beta_launch]: [false]
[persist.device_config.aconfig_flags.configuration.beta_public_launch]: [false]
[persist.device_config.aconfig_flags.configuration.demo_flag]: [false]
[persist.device_config.aconfig_flags.configuration.droidfood_launch]: [false]
[persist.device_config.aconfig_flags.configuration.flag]: [true]
[persist.device_config.aconfig_flags.configuration.flag_five]: [false]
[persist.device_config.aconfig_flags.configuration.flag_four]: [false]
[persist.device_config.aconfig_flags.configuration.flag_six]: [false]
[persist.device_config.aconfig_flags.configuration.flag_three]: [false]
[persist.device_config.aconfig_flags.configuration.flag_two]: [false]
[persist.device_config.aconfig_flags.configuration.public_launch]: [false]
[persist.device_config.aconfig_flags.configuration.rescue_party_throttle_duration_min]: [10]
[persist.device_config.aconfig_flags.connectivity.data_stall_consecutive_dns_timeout_threshold]: [5]
[persist.device_config.aconfig_flags.connectivity.dhcp_init_reboot_enabled]: [false]
[persist.device_config.aconfig_flags.connectivity.dhcp_init_reboot_version]: [0]
[persist.device_config.aconfig_flags.connectivity.dhcp_ip_conflict_detect_version]: [0]
[persist.device_config.aconfig_flags.connectivity.dhcp_rapid_commit_enabled]: [false]
[persist.device_config.aconfig_flags.connectivity.dhcp_rapid_commit_version]: [1]
[persist.device_config.aconfig_flags.connectivity.dhcp_restart_configuration_delay]: [1000]
[persist.device_config.aconfig_flags.connectivity.dhcp_server_decline_version]: [0]
[persist.device_config.aconfig_flags.connectivity.ipclient_accept_ipv6_link_local_dns_version]: [0]
[persist.device_config.aconfig_flags.connectivity.ipclient_multicast_ns_version]: [0]
[persist.device_config.aconfig_flags.edgetpu_native.allowlist_app11]: []
[persist.device_config.aconfig_flags.edgetpu_native.allowlist_app12]: []
[persist.device_config.aconfig_flags.edgetpu_native.allowlist_app5]: []
[persist.device_config.aconfig_flags.edgetpu_native.allowlist_app6]: []
[persist.device_config.aconfig_flags.edgetpu_native.allowlist_app7]: []
[persist.device_config.aconfig_flags.lmkd_native.thrashing_limit_critical]: [300]
[persist.device_config.aconfig_flags.nearby.nearby_enable_presence_broadcast_legacy]: [false]
[persist.device_config.aconfig_flags.nearby.nearby_nano_app_min_version]: [1]
[persist.device_config.aconfig_flags.nearby.nearby_support_test_app]: [false]
[persist.device_config.aconfig_flags.netd_native.dns_event_subsample_map]: [default:6 0:400 2:110 4:110 7:110]
[persist.device_config.aconfig_flags.netd_native.doh]: [1]
[persist.device_config.aconfig_flags.netd_native.dot_connect_timeout_ms]: [30000]
[persist.device_config.aconfig_flags.netd_native.dot_query_timeout_ms]: [-1]
[persist.device_config.aconfig_flags.netd_native.dot_revalidation_threshold]: [-1]
[persist.device_config.aconfig_flags.netd_native.dot_validation_latency_factor]: [3]
[persist.device_config.aconfig_flags.netd_native.dot_validation_latency_offset_ms]: [100]
[persist.device_config.aconfig_flags.netd_native.dot_xport_unusable_threshold]: [-1]
[persist.device_config.aconfig_flags.netd_native.max_cache_entries]: [640]
[persist.device_config.aconfig_flags.netd_native.max_queries_global]: [2500]
[persist.device_config.aconfig_flags.netd_native.no_retry_after_cancel]: [0]
[persist.device_config.aconfig_flags.netd_native.parallel_lookup]: [0]
[persist.device_config.aconfig_flags.netd_native.sort_nameservers]: [0]
[persist.device_config.aconfig_flags.nnapi_native.current_feature_level]: [7]
[persist.device_config.aconfig_flags.nnapi_native.telemetry_enable]: [false]
[persist.device_config.aconfig_flags.remote_key_provisioning_native.enable_rkpd]: [false]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-mods]: [2]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-mods-server]: [2]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-num-mods]: [100]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-num-mods-server]: [100]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-spec]: [1,5,30,60,600]
[persist.device_config.aconfig_flags.runtime_native.metrics.reporting-spec-server]: [1,10,60,3600,*]
[persist.device_config.aconfig_flags.runtime_native.metrics.write-to-statsd]: [true]
[persist.device_config.aconfig_flags.runtime_native.use_app_image_startup_cache]: [true]
[persist.device_config.aconfig_flags.runtime_native_boot.disable_lock_profiling]: [false]
[persist.device_config.aconfig_flags.runtime_native_boot.iorap_blacklisted_packages]: []
[persist.device_config.aconfig_flags.runtime_native_boot.iorap_perfetto_enable]: [false]
[persist.device_config.aconfig_flags.runtime_native_boot.iorap_readahead_enable]: [false]
[persist.device_config.aconfig_flags.runtime_native_boot.iorapd_options]: []
[persist.device_config.aconfig_flags.runtime_native_boot.use_generational_gc]: [true]
[persist.device_config.aconfig_flags.storage_native_boot.charging_required]: [false]
[persist.device_config.aconfig_flags.storage_native_boot.dirty_reclaim_rate]: [0.5]
[persist.device_config.aconfig_flags.storage_native_boot.fuse_enabled]: [1]
[persist.device_config.aconfig_flags.storage_native_boot.lifetime_threshold]: [70]
[persist.device_config.aconfig_flags.storage_native_boot.low_battery_level]: [20.0]
[persist.device_config.aconfig_flags.storage_native_boot.min_gc_sleeptime]: [5000]
[persist.device_config.aconfig_flags.storage_native_boot.min_segments_threshold]: [512]
[persist.device_config.aconfig_flags.storage_native_boot.segment_reclaim_weight]: [2.0]
[persist.device_config.aconfig_flags.storage_native_boot.smart_idle_maint_enabled]: [true]
[persist.device_config.aconfig_flags.storage_native_boot.smart_idle_maint_period]: [60]
[persist.device_config.aconfig_flags.storage_native_boot.take_over_get_content]: [false]
[persist.device_config.aconfig_flags.storage_native_boot.target_dirty_ratio]: [80]
[persist.device_config.aconfig_flags.storage_native_boot.transcode_compat_stale]: []
[persist.device_config.aconfig_flags.surface_flinger_native_boot.SkiaTracingFeature__use_skia_tracing]: [false]
[persist.device_config.nnapi_native.current_feature_level]: [7]
[persist.device_config.nnapi_native.telemetry_enable]: [false]
[persist.device_config.runtime_native.metrics.reporting-mods]: [2]
[persist.device_config.runtime_native.metrics.reporting-mods-server]: [2]
[persist.device_config.runtime_native.metrics.reporting-num-mods]: [100]
[persist.device_config.runtime_native.metrics.reporting-num-mods-server]: [100]
[persist.device_config.runtime_native.metrics.reporting-spec]: [1,5,30,60,600]
[persist.device_config.runtime_native.metrics.reporting-spec-server]: [1,10,60,3600,*]
[persist.device_config.runtime_native.metrics.write-to-statsd]: [true]
[persist.device_config.runtime_native.use_app_image_startup_cache]: [true]
[persist.device_config.runtime_native_boot.disable_lock_profiling]: [false]
[persist.device_config.runtime_native_boot.iorap_blacklisted_packages]: []
[persist.device_config.runtime_native_boot.iorap_perfetto_enable]: [false]
[persist.device_config.runtime_native_boot.iorap_readahead_enable]: [false]
[persist.device_config.runtime_native_boot.iorapd_options]: []
[persist.device_config.runtime_native_boot.use_generational_gc]: [true]
[persist.fuse_sdcard]: [true]
[persist.mm.enable.prefetch]: [true]
[persist.radio.multisim.config]: [dsds]
[persist.rild.nitz_long_ons_0]: []
[persist.rild.nitz_long_ons_1]: []
[persist.rild.nitz_long_ons_2]: []
[persist.rild.nitz_long_ons_3]: []
[persist.rild.nitz_plmn]: []
[persist.rild.nitz_short_ons_0]: []
[persist.rild.nitz_short_ons_1]: []
[persist.rild.nitz_short_ons_2]: []
[persist.rild.nitz_short_ons_3]: []
[persist.rmnet.data.enable]: [true]
[persist.sys.boot.reason]: []
[persist.sys.boot.reason.history]: [bootloader,1763212151
shutdown,userrequested,1763206242
reboot,shell,1763202713]
[persist.sys.dalvik.vm.lib.2]: [libart.so]
[persist.sys.displayinset.top]: [0]
[persist.sys.fairphone.open]: [1]
[persist.sys.fflag.override.settings_bluetooth_hearing_aid]: [true]
[persist.sys.force_sw_gles]: [1]
[persist.sys.fuse]: [true]
[persist.sys.isdtcarrier]: [0]
[persist.sys.lmk.reportkills]: [true]
[persist.sys.locale]: [fr-FR]
[persist.sys.sf.color_mode]: [0]
[persist.sys.sf.color_saturation]: [1.0]
[persist.sys.time.dst_offset]: [-3600000]
[persist.sys.time.dst_transition]: [1761440400000]
[persist.sys.time.offset]: [7200000]
[persist.sys.timezone]: [Europe/Paris]
[persist.sys.usb.config]: [adb]
[persist.sys.wfd.virtual]: [0]
[persist.timed.enable]: [true]
[persist.traced.enable]: [1]
[persist.vendor.dpm.feature]: [11]
[persist.vendor.dpm.tcm]: [2]
[persist.wm.extensions.enabled]: [true]
[pm.dexopt.ab-ota]: [speed-profile]
[pm.dexopt.bg-dexopt]: [speed-profile]
[pm.dexopt.boot-after-mainline-update]: [verify]
[pm.dexopt.boot-after-ota]: [verify]
[pm.dexopt.cmdline]: [verify]
[pm.dexopt.first-boot]: [verify]
[pm.dexopt.inactive]: [verify]
[pm.dexopt.install]: [speed-profile]
[pm.dexopt.install-bulk]: [speed-profile]
[pm.dexopt.install-bulk-downgraded]: [verify]
[pm.dexopt.install-bulk-secondary]: [verify]
[pm.dexopt.install-bulk-secondary-downgraded]: [verify]
[pm.dexopt.install-fast]: [skip]
[pm.dexopt.post-boot]: [verify]
[pm.dexopt.shared]: [speed]
[qcom.hw.aac.encoder]: [true]
[remote_provisioning.enable_rkpd]: [true]
[remote_provisioning.hostname]: [remoteprovisioning.googleapis.com]
[ril.ecclist]: [911,112,000,08,110,119,118,133,120,999]
[ril.ecclist1]: [911,112,000,08,110,119,118,133,120,999]
[ril.subscription.types]: [NV,RUIM]
[ro.accessibility.support_hidraw]: [false]
[ro.actionable_compatible_property.enabled]: [true]
[ro.adb.secure]: [1]
[ro.af.client_heap_size_kbyte]: [7168]
[ro.allow.mock.location]: [0]
[ro.apex.updatable]: [true]
[ro.baseband]: [msm]
[ro.bluetooth.library_name]: [libbluetooth_qti.so]
[ro.board.api_level]: [30]
[ro.board.first_api_level]: [30]
[ro.board.platform]: [lito]
[ro.boot.CID]: [2080]
[ro.boot.avb_version]: [1.1]
[ro.boot.baseband]: [msm]
[ro.boot.boot_devices]: [soc/1d84000.ufshc]
[ro.boot.bootdevice]: [1d84000.ufshc]
[ro.boot.bootreason]: [bootloader]
[ro.boot.console]: [ttyMSM0]
[ro.boot.dtb_idx]: [0]
[ro.boot.dtbo_idx]: [0]
[ro.boot.dynamic_partitions]: [true]
[ro.boot.flash.locked]: [0]
[ro.boot.fstab_suffix]: [default]
[ro.boot.hardware]: [qcom]
[ro.boot.insecure]: [false]
[ro.boot.keymaster]: [1]
[ro.boot.memcg]: [1]
[ro.boot.serialno]: [4b418009]
[ro.boot.slot_suffix]: [_a]
[ro.boot.usbcontroller]: [a600000.dwc3]
[ro.boot.vbmeta.avb_version]: [1.0]
[ro.boot.vbmeta.device]: [PARTUUID=6b8248c0-1e17-38af-3540-50c26ecdfdeb]
[ro.boot.vbmeta.device_state]: [unlocked]
[ro.boot.vbmeta.digest]: [874e801bf39c67fe3f11a0cac0fa3ffe3d62cf078e15f23658f2e8fff28c8de0]
[ro.boot.vbmeta.hash_alg]: [sha256]
[ro.boot.vbmeta.invalidate_on_error]: [yes]
[ro.boot.vbmeta.size]: [8960]
[ro.boot.verifiedbootstate]: [orange]
[ro.boot.veritymode]: [enforcing]
[ro.bootimage.build.date]: [Thu Sep 11 10:16:13 CEST 2025]
[ro.bootimage.build.date.utc]: [1757578573]
[ro.bootimage.build.fingerprint]: [Fairphone/FP4eea/FP4:11/FP4.QREL.14.28.3/14.28.3:user/release-keys]
[ro.bootloader]: [unknown]
[ro.bootmode]: [unknown]
[ro.build.ab_update]: [true]
[ro.build.backported_fixes.alias_bitset.long_list]: [2]
[ro.build.characteristics]: [nosdcard]
[ro.build.date]: [Tue Sep 23 10:01:08 CEST 2025]
[ro.build.date.utc]: [1758614468]
[ro.build.description]: [FP4-user 15 FP4.QREL.15.14.3 15.14.3 release-keys]
[ro.build.display.id]: [FP4.QREL.15.14.3]
[ro.build.fingerprint]: [Fairphone/FP4eea/FP4:15/FP4.QREL.15.14.3/15.14.3:user/release-keys]
[ro.build.flavor]: [FP4-user]
[ro.build.host]: [jenkins-agent-01]
[ro.build.id]: [FP4.QREL.15.14.3]
[ro.build.product]: [FP4]
[ro.build.tags]: [release-keys]
[ro.build.type]: [user]
[ro.build.user]: [jenkins]
[ro.build.version.all_codenames]: [REL]
[ro.build.version.base_os]: []
[ro.build.version.codename]: [REL]
[ro.build.version.incremental]: [15.14.3]
[ro.build.version.known_codenames]: [Base,Base11,Cupcake,Donut,Eclair,Eclair01,EclairMr1,Froyo,Gingerbread,GingerbreadMr1,Honeycomb,HoneycombMr1,HoneycombMr2,IceCreamSandwich,IceCreamSandwichMr1,JellyBean,JellyBeanMr1,JellyBeanMr2,Kitkat,KitkatWatch,Lollipop,LollipopMr1,M,N,NMr1,O,OMr1,P,Q,R,S,Sv2,Tiramisu,UpsideDownCake,VanillaIceCream]
[ro.build.version.min_supported_target_sdk]: [28]
[ro.build.version.preview_sdk]: [0]
[ro.build.version.preview_sdk_fingerprint]: [REL]
[ro.build.version.release]: [15]
[ro.build.version.release_or_codename]: [15]
[ro.build.version.release_or_preview_display]: [15]
[ro.build.version.sdk]: [35]
[ro.build.version.security_patch]: [2025-10-05]
[ro.carrier]: [unknown]
[ro.com.android.dataroaming]: [false]
[ro.com.google.clientidbase]: [android-alcatel]
[ro.com.google.gmsversion]: [15_202507]
[ro.com.google.lens.oem_camera_package]: [com.fp.camera]
[ro.com.google.lens.oem_image_package]: [com.fp.camera]
[ro.config.alarm_alert]: [Alarm_Classic.ogg]
[ro.config.notification_sound]: [pixiedust.ogg]
[ro.config.ringtone]: [Sunbeam.mp3]
[ro.control_privapp_permissions]: [enforce]
[ro.crypto.dm_default_key.options_format.version]: [2]
[ro.crypto.metadata.enabled]: [true]
[ro.crypto.state]: [encrypted]
[ro.crypto.type]: [file]
[ro.crypto.volume.filenames_mode]: [aes-256-cts]
[ro.crypto.volume.metadata.method]: [dm-default-key]
[ro.dalvik.vm.enable_uffd_gc]: [true]
[ro.dalvik.vm.native.bridge]: [0]
[ro.debuggable]: [0]
[ro.force.debuggable]: [0]
[ro.frp.pst]: [/dev/block/bootdevice/by-name/frp]
[ro.fuse.bpf.is_running]: [false]
[ro.gfx.driver.1]: [com.qualcomm.qti.gpudrivers.lito.api30]
[ro.hardware]: [qcom]
[ro.hardware.egl]: [adreno]
[ro.hardware.nfc_nci]: [pn54x]
[ro.hardware.vulkan]: [adreno]
[ro.hwui.drop_shadow_cache_size]: [6]
[ro.hwui.gradient_cache_size]: [1]
[ro.hwui.layer_cache_size]: [48]
[ro.hwui.path_cache_size]: [32]
[ro.hwui.r_buffer_cache_size]: [8]
[ro.hwui.text_large_cache_height]: [1024]
[ro.hwui.text_large_cache_width]: [2048]
[ro.hwui.text_small_cache_height]: [1024]
[ro.hwui.text_small_cache_width]: [1024]
[ro.hwui.texture_cache_flushrate]: [0.4]
[ro.hwui.texture_cache_size]: [72]
[ro.hwui.use_vulkan]: []
[ro.kernel.qemu.gles]: [0]
[ro.kernel.version]: [4.19]
[ro.launcher.blur.appLaunch]: [0]
[ro.llndk.api_level]: [202404]
[ro.logd.size.stats]: [64K]
[ro.media.recorder-max-base-layer-fps]: [60]
[ro.nfc.port]: [I2C]
[ro.odm.build.date]: [Thu Sep 11 10:16:13 CEST 2025]
[ro.odm.build.date.utc]: [1757578573]
[ro.odm.build.fingerprint]: [Fairphone/FP4eea/FP4:11/FP4.QREL.14.28.3/14.28.3:user/release-keys]
[ro.odm.build.media_performance_class]: [30]
[ro.odm.build.version.incremental]: [14.28.3]
[ro.oem.key1]: [fp4s_client_1]
[ro.opa.eligible_device]: [true]
[ro.opengles.version]: [196610]
[ro.postinstall.fstab.prefix]: [/system]
[ro.product.ab_ota_partitions]: [product,system,system_ext,vbmeta,vbmeta_system]
[ro.product.board]: [FP4]
[ro.product.brand]: [Fairphone]
[ro.product.build.date]: [Tue Sep 23 10:01:08 CEST 2025]
[ro.product.build.date.utc]: [1758614468]
[ro.product.build.fingerprint]: [Fairphone/FP4eea/FP4:15/FP4.QREL.15.14.3/15.14.3:user/release-keys]
[ro.product.build.id]: [FP4.QREL.15.14.3]
[ro.product.build.tags]: [release-keys]
[ro.product.build.type]: [user]
[ro.product.build.version.incremental]: [15.14.3]
[ro.product.build.version.release]: [15]
[ro.product.build.version.release_or_codename]: [15]
[ro.product.build.version.sdk]: [35]
[ro.product.cpu.abi]: [arm64-v8a]
[ro.product.cpu.abilist]: [arm64-v8a,armeabi-v7a,armeabi]
[ro.product.cpu.abilist32]: [armeabi-v7a,armeabi]
[ro.product.cpu.abilist64]: [arm64-v8a]
[ro.product.cpu.pagesize.max]: [4096]
[ro.product.device]: [FP4]
[ro.product.first_api_level]: [30]
[ro.product.locale]: [en-US]
[ro.product.manufacturer]: [Fairphone]
[ro.product.model]: [FP4]
[ro.product.name]: [FP4eea]
[ro.product.odm.brand]: [Fairphone]
[ro.product.odm.device]: [FP4]
[ro.product.odm.manufacturer]: [Fairphone]
[ro.product.odm.model]: [FP4]
[ro.product.odm.name]: [FP4eea]
[ro.product.product.brand]: [Fairphone]
[ro.product.product.device]: [FP4]
[ro.product.product.manufacturer]: [Fairphone]
[ro.product.product.model]: [FP4]
[ro.product.product.name]: [FP4]
[ro.product.property_source_order]: [odm,vendor,product,system_ext,system]
[ro.product.system.brand]: [Fairphone]
[ro.product.system.device]: [FP4]
[ro.product.system.manufacturer]: [Fairphone]
[ro.product.system.model]: [FP4]
[ro.product.system.name]: [FP4eea]
[ro.product.system_ext.brand]: [Fairphone]
[ro.product.system_ext.device]: [FP4]
[ro.product.system_ext.manufacturer]: [Fairphone]
[ro.product.system_ext.model]: [FP4]
[ro.product.system_ext.name]: [FP4]
[ro.product.vendor.brand]: [Fairphone]
[ro.product.vendor.device]: [FP4]
[ro.product.vendor.manufacturer]: [Fairphone]
[ro.product.vendor.model]: [FP4]
[ro.product.vendor.name]: [FP4eea]
[ro.property_service.version]: [2]
[ro.revision]: [0]
[ro.secure]: [1]
[ro.serialno]: [4b418009]
[ro.setupwizard.rotation_locked]: [true]
[ro.sf.lcd_density]: [420]
[ro.soc.manufacturer]: [QTI]
[ro.soc.model]: [SM7225]
[ro.support_one_handed_mode]: [true]
[ro.surface_flinger.force_hwc_copy_for_virtual_displays]: [true]
[ro.surface_flinger.has_HDR_display]: [true]
[ro.surface_flinger.has_wide_color_display]: [true]
[ro.surface_flinger.max_frame_buffer_acquired_buffers]: [3]
[ro.surface_flinger.max_virtual_display_dimension]: [4096]
[ro.surface_flinger.protected_contents]: [true]
[ro.surface_flinger.set_touch_timer_ms]: [200]
[ro.surface_flinger.use_color_management]: [true]
[ro.surface_flinger.wcg_composition_dataspace]: [143261696]
[ro.system.build.date]: [Tue Sep 23 10:01:08 CEST 2025]
[ro.system.build.date.utc]: [1758614468]
[ro.system.build.fingerprint]: [Fairphone/FP4eea/FP4:15/FP4.QREL.15.14.3/15.14.3:user/release-keys]
[ro.system.build.id]: [FP4.QREL.15.14.3]
[ro.system.build.tags]: [release-keys]
[ro.system.build.type]: [user]
[ro.system.build.version.incremental]: [15.14.3]
[ro.system.build.version.release]: [15]
[ro.system.build.version.release_or_codename]: [15]
[ro.system.build.version.sdk]: [35]
[ro.system.product.cpu.abilist]: [arm64-v8a,armeabi-v7a,armeabi]
[ro.system.product.cpu.abilist32]: [armeabi-v7a,armeabi]
[ro.system.product.cpu.abilist64]: [arm64-v8a]
[ro.system_ext.build.date]: [Tue Sep 23 10:01:08 CEST 2025]
[ro.system_ext.build.date.utc]: [1758614468]
[ro.system_ext.build.fingerprint]: [Fairphone/FP4eea/FP4:15/FP4.QREL.15.14.3/15.14.3:user/release-keys]
[ro.system_ext.build.id]: [FP4.QREL.15.14.3]
[ro.system_ext.build.tags]: [release-keys]
[ro.system_ext.build.type]: [user]
[ro.system_ext.build.version.incremental]: [15.14.3]
[ro.system_ext.build.version.release]: [15]
[ro.system_ext.build.version.release_or_codename]: [15]
[ro.system_ext.build.version.sdk]: [35]
[ro.tct.boot.ver]: [BTW1Z0Z8TA00]
[ro.tct.modem.ver]: [NTW1Z0Z8TA00]
[ro.tct.rec.ver]: [RTW1Z0Z8TA00]
[ro.tct.study.ver]: [STW1Z0Z8TA00]
[ro.tct.sys.ver]: [YTW1Z0Z8TA00]
[ro.telephony.call_ring.multiple]: [false]
[ro.telephony.default_network]: [26,26]
[ro.telephony.iwlan_operation_mode]: [AP-assisted]
[ro.telephony.sim_slots.count]: [2]
[ro.treble.enabled]: [true]
[ro.vendor.api_level]: [30]
[ro.vendor.build.date]: [Thu Sep 11 10:16:13 CEST 2025]
[ro.vendor.build.date.utc]: [1757578573]
[ro.vendor.build.fingerprint]: [Fairphone/FP4eea/FP4:11/FP4.QREL.14.28.3/14.28.3:user/release-keys]
[ro.vendor.build.id]: [FP4.QREL.14.28.3]
[ro.vendor.build.security_patch]: [2025-10-05]
[ro.vendor.build.tags]: [release-keys]
[ro.vendor.build.type]: [user]
[ro.vendor.build.version.incremental]: [14.28.3]
[ro.vendor.build.version.release]: [11]
[ro.vendor.build.version.release_or_codename]: [11]
[ro.vendor.build.version.sdk]: [30]
[ro.vendor.product.cpu.abilist]: [arm64-v8a,armeabi-v7a,armeabi]
[ro.vendor.product.cpu.abilist32]: [armeabi-v7a,armeabi]
[ro.vendor.product.cpu.abilist64]: [arm64-v8a]
[ro.vendor.qti.va_aosp.support]: [1]
[ro.vendor.qti.va_odm.support]: [1]
[ro.virtual_ab.enabled]: [true]
[ro.vndk.version]: [30]
[ro.wifi.channels]: []
[ro.zygote]: [zygote64_32]
[security.perf_harden]: [1]
[selinux.restorecon_recursive]: [/data/misc_ce/0]
[service.bootanim.exit]: [1]
[service.bootanim.progress]: [0]
[service.sf.present_timestamp]: [1]
[servicemanager.ready]: [true]
[setupwizard.theme]: [glif_v3_light]
[sys.boot.reason]: [bootloader]
[sys.boot.reason.last]: [bootloader]
[sys.boot_completed]: [1]
[sys.bootstat.first_boot_completed]: [1]
[sys.fuse.transcode_enabled]: [true]
[sys.init.perf_lsm_hooks]: [1]
[sys.oem_unlock_allowed]: [0]
[sys.qca1530]: [detect]
[sys.sysctl.extra_free_kbytes]: [29615]
[sys.system_server.start_count]: [1]
[sys.system_server.start_elapsed]: [8461]
[sys.system_server.start_uptime]: [8461]
[sys.usb.config]: [mtp,adb]
[sys.usb.configfs]: [1]
[sys.usb.controller]: [a600000.dwc3]
[sys.usb.mtp.device_type]: [3]
[sys.usb.state]: [mtp,adb]
[sys.use_memfd]: [false]
[sys.user.0.ce_available]: [true]
[sys.vendor.shutdown.waittime]: [500]
[sys.wifitracing.started]: [-1]
[telephony.active_modems.max_count]: [2]
[telephony.lteOnCdmaDevice]: [1]
[tunnel.audio.encode]: [true]
[use.voice.path.for.pcm.voip]: [true]
[vendor.display.comp_mask]: [0]
[vendor.display.disable_excl_rect]: [0]
[vendor.display.disable_excl_rect_partial_fb]: [1]
[vendor.display.disable_hw_recovery_dump]: [1]
[vendor.display.disable_idle_time_hdr]: [1]
[vendor.display.disable_idle_time_video]: [1]
[vendor.display.disable_offline_rotator]: [1]
[vendor.display.disable_scaler]: [0]
[vendor.display.enable_allow_idle_fallback]: [1]
[vendor.display.enable_async_powermode]: [1]
[vendor.display.enable_camera_smooth]: [1]
[vendor.display.enable_hdr10_gpu_target]: [1]
[vendor.display.enable_optimize_refresh]: [1]
[vendor.display.enable_perf_hint_large_comp_cycle]: [1]
[vendor.display.enable_posted_start_dyn]: [1]
[vendor.display.use_smooth_motion]: [1]
[vendor.gralloc.disable_ubwc]: [0]
[vold.has_adoptable]: [1]
[vold.has_compress]: [0]
[vold.has_quota]: [1]
[vold.has_reserved]: [1]
[zygote.critical_window.minute]: [10]
If you still don’t get a dialog to accept the request, then that’s the reason it fails.
Open Magisk, go to Superuser in the bottom toolbar, disable authorization for root request (meaning any request should be accepted automatically).
I can’t tell you the exact naming of the option sorry, I don’t currently have access to a phone with an unlocked bootloader so that menu isn’t accessible to me ![]()
Let’s hope that will get the command to pass ![]()
Good evening, hirnsushi,
Well, I finally managed to run the command su -c resetprop ro.boot.flash.locked 1. I got a message on my phone confirming that the command was successful.
To do this, I had to change the Magisk settings (disable “Random output name” and select “Hide Magisk application”).
I went into “Developer options.” “OEM unlocking” is no longer grayed out, so I can move the slider to allow the bootloader to be unlocked… BUT the “Enable” button is grayed out and unavailable.
I am currently running the patched boot with Magisk enabled as described above.
I have the option to uninstall Magisk; when I click on the red “Uninstall Magisk” button, I get a message saying:
All modules will be disabled or removed! Superuser access will be lost! Your data may be encrypted if it is not already.
IMAGE RESTORATION
COMPLETE UNINSTALL
I am hesitant to perform either of these two actions…
There is certainly an adb command to replace manual unlocking. I would like to be sure I am using the correct command. Is the command adb shell su -c setprop sys.oem_unlock_allowed 1 runable ? I mean, won’t it break the system?
I’m having a really hard time with all of this.
The screenshot seems to indicate that you’ll need a bootloader unlock code after all, the part below the text looks like a text input and the header is “Input verify code”.
You should be able to activate it once you input the code.
You don’t need to uninstall Magisk, the next step after enabling OEM unlocking is flashing factory images again anyway, once you flip the switch you can continue here.
Yeah, I’m really sorry, it’s a mess. The Fairphone docs / installation scripts are just lacking, have been for years. There would be so many ways to improve this process, make it safer, but I’ve given up, even simple fixes aren’t made.
There are several custom ROMs with accessible GUI installers, that not only guide you through the process, but make locking the bootloader actually safer.
Actually installing Fairphone OS yourself has always been an afterthought, and it shows… ![]()
I mean all they would have to do to make locking fundamentally more safe would be to replace the reboot part of the script with something like:
read -p 'Do you want to lock the bootloader? [y|N]: ' lock
case "${lock}" in
y|Y) fastboot flashing lock ;;
*) fastboot reboot
esac
That alone would have prevented sooo many bricks, and saved support (which includes volunteers on this forum) a lot of time, but it just doesn’t get better, no one cares.
I apologize for the short rant ![]()
Of course!
In the end, after trying so many things, I was stuck in a tunnel and couldn’t see the obvious solution!
Well, that’s it, I managed to restore the phone to factory settings with a locked bootloader… it’s like new!
Thank you so much, hirnsushi, you put me on the right track. It was a struggle, but I learned a lot and understood a lot of things.
Thank you, thank you so much. And thanks to Volker too.
This really needs to be added to the official installation instructions! I didn’t catch the automatic reboot the first time and my unlock_ability of course got reset to 0. Got it handled on the second try, but I’ll just add one crucial detail that almost tripped me up: You have to reboot to bootloader after the installation for unlock_ability to get set back to 1.
I missed the REBOOT_TO_BOOTLOADER flag when I poked around in the script and instead set AUTO_REBOOT to false, thinking I could then relock the bootloader before rebooting. But without a reboot get_unlock_ability was still stuck at 0, so I had to go Volker’s route and press vol-down while letting the script reboot my phone (this time at least at my command and not automatically).
