when i scroll through a web page with firefox or chrome the text is blurred. It looks very ugly. Is this a hardware problem or a problem with the software that can be fixed?
Hi Clara,
do you mean blurred while scrolling? That is probably normal. Blurred after scrolling would be an issue. Could you post a screenshot?
Best wishes,
Thomas
Yes, while scrolling. I cant make a Screenshot while i scroll through a page, sorry.
Normal means normal for all Smartphones or normal for fairphone?
Have you installed some kind of theme/layer/skin for your Fairphone?
It seems it depends on the display or display technology used, the internet suggests it’s more or less noticeable across the board of smartphones.
It a pure fairphoneOS without any Modifikation.
Normal for all Smartphones. It might be less obvious on phones with a very high screen refresh rate (there are 90 Hz displays out there, mostly appealing to avid gamers).
In my everyday usage, I never perceived text on the FP3 display blurred, let alone ugly. I have to admit, though, that I do not read text while scrolling. I simply read and scroll alternatingly, I guess. So what you described is not an issue for me.
On my FP2, I always had this and never thought it was abnormal. It’s always a bit blurry, but as @teezeh said, I read when I finished scrolling, not during scrolling
Otherwise, did you notice a difference between battery saver on/off?
Or in the options, on LineageOS 17.1, I have an slider option to choose between battery efficiency and device performance. When it is on max battery saving, animations such as scrolling are always a bit laggy. I don’t know the FP3, but perhaps in Pie there is such an option, perhaps others can confirm.
