Hi, so my four year old Fairphone 2 just decided to die on me.
I was using it, scrolling through Instagram when the screen flashed and then turned black. It wouldn’t react to anything after that.
I removed the battery and tried to restart it, but all it would do is show a blue screen for 10 sec after the company logo. Then it turns to black again and won’t react to anything.
I have already realised this is most likely a motherboard issue. But I am unsure as to how I could proceed now. Is there a repair possibility offered by Fairphone and if yes, how do I approach them?
Or does this mean it is time for a new phone, after only four years?
If you happen to have #fairphoneangels in your vicinity, perhaps a module swap could help identify whether it’s really the mainboard (= core module).
If so, you could try the #market category for second hand options, or …
Beforehand you could also try to disassemble the phone, carefully clean the module contacts, and put everything back together. Here’s a nice video (without the cleaning) …
I have just tried this method as well, but the device keeps crashing into blue screen. I guess it is a hardware problem.
Thanks for all the tips anyway!
