I don’t get any error, just a empty list to choose from.
Measures that did not help:
- enabling Chrome, Google, My Fairphone app
- allowing WiFi download
- forcing mobile connection
- manually triggering the download
Has anyone had a similar issue with Blokada?
Just downloaded the update from 5th December
Did you update to Blokada 5? That works fine for me on android 9 (but 4.x also worked fine).
You could try PersonalDNSfilter. I used Blockada in the past and found PersonalDNSfilter better (and not requesting root).
that’s new though - and works
Though, it is strange v4 does not work.
Why do you find it better?
