Some months ago, i accidentally dropped my fairphone 3 on some stairs and since that, there as been a black area in the top right corner of the display. I probably just need to buy a new diaplay. But before i spend 90 euros on a new display, I would like someone to confirm, that it is indeed to right solution to the issue.
No one can tell you for sure, whats wrong. Did you try to remove the display already and reseat it properly?
Is there probably a Fairphone Angel in your vicinity, who can help you testing your device?
No, I haven’t tried removing and restarting the display. I will try that, and write back when it’s done.
A picture of the issue (maybe on some different background colors) would also be helpful. If you have a second phone with which to take the picture.
