Best utility apps for Fairphone
I used Clean Master and Battery Doctor on my Galaxy but I find that these apps make the Fairphone buggy. What utility apps do you recommend for maintenance and power management? I’m willing to pay if it’s worth it.
I don’t use any, because most - even the well known ones - are a scam anyway.
One that is often recommended on the forum and actually seems to work though is Greenify.
instread of clean master I recommend Files even if it comes from google. But it has no ads at all and works very well.
To cut the tentacles of Zuckerbergs anti-social media, google and annoying ads, have a look at Blockada
