In places where the signal is weak, it constantly tries to switch between the Wifi and the phone network, and there is no signal / connection at all at that time.
I also noticed that I do not get a “login page” on public Wifi networks (where you usually have to press “I accept”). There is just a “page not found” error message, and the page might only appear for a very short time. At one time, it worked anyway, but only for one minute.
However, on two Wifi networks I am “regulary” connected to, everything works fine (unless in spots where the signal is weak).
Today I’ve had the problem “constantly tries to switch between Wifi and mobile data, and then there is no signal at all” in a situation when the Wifi signal was strong enough. Looks like this is “triggered” by an app, and it can be “fixed” with a reboot.
(It is annoying that is asks for the PIN when rebooting and does not accept a fingerprint, but this is probably a forced “security feature” you cannot turn off).
I still have this problem, and using “Use network as it is” and opening a local IP adresss like 192.168.1.1 in another browser seems to work to get the login page. It might also work to try the “Gateway” IP adress from the connection information / network details.
When it worked for some time, the “portal page” with local information etc. sometimes closed immediatley.
It looks like I am the only one with this problem, and at least there is a somewhat working workaround. By opening 192…, I open a webpage from the local router of the public Wifi network, which should appear automatically, but does not. At least on some “experiments”, this opens the “captive portal” / login page.
I’ve also heard that you should open a http and not https website before trying to connect to such a public Wifi network, if this problem occurs. Did not really work.
