Since I installed the latest Google security update (#2 Thu Aug 5) on early September the battery charge behaves significantly erratically.
Sometimes, everything is fine.
Most of the time, while the charger is plugged in, it displays “slow charge” (even though I also tried with fast charge it displays the same) and the battery charge percentage does not go up. Even worse, it gets down, as if drainage > charge.
I can’t recognize any pattern related to anything other reason.
Before acquiring a new battery to the store, I’d like to know if someone encountered the same issue and if I did something wrong.
I acquired the FP3 two years ago. During that time I tried using fast charge as few as possible, and always tried to maintain the charge between 20 and 80%.
Is this a new occurrence that you are linking to the latest 0129 update?
@crashtib by the way the update, although incorporating a security update is not the whole update. I.e. if it is a consequence of the update it’s more likely to be related to the Fairphone OS update.
It’s okay, please do. I did that mostly to facilitate google searches for futures users who might have the same issue, but reading the answers here seem to demonstrate that the link may be untrue.
I had the same issue, switched chargers from one official charger to another and after that I never saw it again. So probably either charging cable or charger problem.
