Battery % only visible after unlocking screen
I used to be able to see the battery % in the ‘wipe down menu’ (with the flashlight, airplane mode, wifi-on/off etc). Since I updated to Android 10, this menu does no longer contain the %. To see this, I need to unlock the screen. Only then, does the wipe down menu show the percentage.
I find this annoying. Does anyone know how this can be helped (i.e. so I can see the % without having to unlock first)?
Thanks!
On my FP2 running Fairphone Open this doesn’t happen. I see the battery percentage in the notification bar (at the very top) both of the lock screen and the unlocked screen.
This should usually be controlled through Settings > Battery > Battery percentage.
Check, I found it. Thanks!
