TL;DR try turning your phone fully off (hold the power button, then tap “Power off”), then turn it on again
Full version: Just wanted to chip in since I have a similar issue: every now and then my FP3 suddenly drains like 8% battery per night instead of 2% (I keep it in airplane mode at night). When that happens, the battery also drains faster than normal during the day.
The Battery usage screen did not show anything useful, so I installed GSAM and gave it all the fancy developer permissions I could give it. Turns out the extra battery drain could not be attributed to any app or system functionality. I also spent hours analyzing logcat output to no avail.
In the end, I found that turning my phone fully off and then turning it on again brings it back to normal battery drain figures. Sometimes it reverts to fast draining in a day or two, sometimes it doesn’t for weeks. Every time it happens, the drain continues until I turn the phone fully off and on again. I decided to just live with it, regular power cycling has some security benefits anyway
