Battery drain after latest update
Hi, my FP4 gets drained of battery within 6-8 hours. It seems to have started after the latest OS update which i did a few days ago. The weather is cold outside, but this happpens when I am inside as well. The phone is only a year old. What to do?
Check the battery consumption of your apps. There’s probably one running wild.
I wore down my first battery after a year. It got to around 80 % original capacity, was getting worse and it acted really weirdly in winter weather. When using it outside (-5 °C), the charge went from 100 to 0 in less than hour and then back to 90 when charging in less than 5 minutes. It’s my work phone so I just ordered a new battery and it went back to normal. That one lasted a bit more than 1.5 years, so now I’m on the third one after three years.
So it can be worn out battery after a year, but as Incanus said, first check battery usage.
