Hi all!
I found that one battery contact of my FP2 is somehow twisted and I like to replace the contacts.
Does someone know where to get a spare part?
Best wishes Udo
Hi Udo, if I’m not wrong, this is part of the core module. So are you searching for a working core modul? If so, this is no spare part sold by FP and you would need to buy a used FP2, so I would suggest to move your post to the market section and to check ebay.
Well, it depends if you are ready and able to solder away the contacts and resolder them on your own core-module, in which case I might have a dead core-module lying around with (I presume) intact contacts which you could use.
If you are asking for a spare part, this topic should indeed be moved to the #market:buy category.
Hello Alex, I will give it a try.
Is there a way to contact each other without publishing email or phone number?
