Avoid bootloop/bricked FP4 when flashing /e/OS
I just got my brand new FP4 yesterday and intend to flash /e/ OS onto it.
Looking at the /e/ OS documentation for the FP4 I noticed a warning saying:
Caution: Ensure that you flash an image with a security patch level greater than the level of the existing security patch, Failure to do so will brick your device.
Since I already installed the (as of now) latest update on my device, my security patch level is not March 5th, while the latest stable release image of /e/ OS apparently dates to the 24th of Febuary.
Being the impatient person I am, I tried to find out when to expect the next release of /e/ and came across this open issue:
I understand the problem is triggered by the final step, where the bootloader is locked again, right?
One of the devs explicitly says
You will be able to lock your bootloader after flashing an upcoming release with a newer security patch level.
and
It should be ok with a over the air update but relocking the bootloader afterwards might force you to set everything up again.
So guess I’ll give that I try tonight.
What are the dangers of using a phone with the bootloader unlocked for a few weeks? I assume this mostly allows anyone to connect it to their PC and have full access or am I missing something REALLY bad, as in “remote exploit bad”?
If you’re reading this and are quite certain I’m heading for disaster, a little heads up would be nice. :sweat_smile:
Maybe this answers your question?
Yes, regarding the unlocked bootloader it does. That’s basically what I thought. I think, I can live with that for a couple of weeks. :+1:
Thx!
I just installed /e/ OS successfully without bootloop by following the instructions of the official documentation, but simply skipping the paragraph “Locking the Bootloader”. So my bootloader is still unlocked, I see a warning at boot, but it boots just fine. :+1:
PS: I assume this is just normal behaviour, but when running the fastboot commands to unlock the bootloader, the phone rebooted a significant amount of times. It took several minutes, but it always managed to finish whatever it was doing and came back working. So as usual: Patience is key! :sweat_smile:
Maybe the system was trying one of the slots which was “unbootable”. So it tried to boot that about 6 times and changed to the other (bootable) slot then.
You can check that if you want by going to Fastboot mode and typing in fastboot getvar all and searching for unbootable slots (slot-unbootable).
On unlocking the bootloader I’ve just seen my device rebooting for clearing the data partition and rebooting again a second time after that.
Hi guys.
I’m new here, as I received my Fairphone 2 days ago and installed /e/ almost immediately.
Just to keep you informed that as of yesterday with up-to-date software, bootloader issue is still there :slightly_smiling_face:
Anyway, glad to have a functioning /e/ OS and a great FP4
As with @Azimoth , I was able to successfully install /e/OS on my new FP4. But I did NOT skip the last section and this was my undoing. I would rather see the warning that be stuck in the locked bootloader.
I think some steps are missing from the instructions…
@Volker I see the following with your suggestion
slot-unbootable:a:yes
but
slot-unbootable:b:no
How were you able to switch into the bootable slot?
Any help here would be great.
Which active slot is shown by fastboot getvar all?
You may try fastboot --set-active=b.
but maybe this command won’t work as you seem to have relocked your bootloader.
You may just try to boot several times and the phone should automatically switch to the other slot.
Did you already try to unlock the bootloader again by fastboot flashing unlock?
Slot a ist active
Both commands are not working.
gives
Setting current slot to 'b'
FAILED (remote: 'Slot Change is not allowed in Lock State')
and
gives
FAILED (remote: 'Flashing Unlock is not allowed')
Well, I’m afraid it doesn’t look too promising… :frowning:
What’s the output of fastboot flashing get_unlock_ability?
Did you try to boot various times? The mentioned getvar all command should show the remaining attempts for slot a.
You still might try out another factory reset.
If nothing helps you’ll have to have a look at
gives
(bootloader) get_unlock_ability: 0
OKAY [  0.001s]
Finished. Total time: 0.001s
fastboot getvar all
alway gives the following despite numerous reboots (no indexing of counts etc)
(bootloader) has-slot:modem:yes
(bootloader) has-slot:system:no
(bootloader) current-slot:a
(bootloader) has-slot:boot:yes
(bootloader) slot-retry-count:b:7
(bootloader) slot-unbootable:b:no
(bootloader) slot-successful:b:no
(bootloader) slot-retry-count:a:6
(bootloader) slot-unbootable:a:yes
(bootloader) slot-successful:a:yes
(bootloader) slot-count:2
Thanks for the tip and link, will take a look.
How do I do a factory reset from the bootloader?
Are
fastboot erase userdata
fastboot erase metadata
allowed commands in the status of your phone? They should do it.
But honestly I’m not too optimistic for your device except a repair at Cordon…
Ok, yeah, I tried those commands already. Same locked error as the other fun commands.
Nein…nein… Trotzdem vielen Dank!
Doesn’t /e/ ship with a recovery you could use to wipe data / factory reset? (I’ve never used /e/)
What happens when you use fastboot reboot recovery, select Recovery mode in the bootloader menu or boot into fastbootd (fastboot reboot fastboot) and select Enter recovery? :thinking:
Both procedures just restart to the bootloader.
Thanks for the idea with the recovery image.
fastboot flash recovery recovery.img
gives
Sending 'recovery' (98304 KB)
OKAY [  3.865s]
Writing 'recovery'
FAILED (remote: 'Flashing is not allowed in Lock State')
fastboot boot recovery.img
gives
Sending 'boot.img' (98304 KB)
OKAY [  3.625s]
Booting
FAILED (remote: 'Fastboot boot command is not available in locked device')
Is there another way to boot from the image?
No, sorry, booting an .img needs fastboot boot and that only works with an unlocked bootloader.
So /e/ really doesn’t have a recovery, huh? :astonished:
They (/e/) have a recovery. But if I remember well, if the device does not boot because of a “corrupt” system you can’t reach any recovery system…
Indeed, it gave me a corrupt system error before locking me into the bootloader. :cry:
I assume its like here, with the difference you cant unlock the bootloader again…as you have get unlock ability=0
Just adding as there are screenshots on gitlab
Interesting :thinking:
I only asked because the last user with a bricked Calyx install could still access recovery.
Maybe A11 vs. A12 makes the difference here? A12 moved recovery to fastbootd.
Either way it didn’t help in the other case, so it probably wouldn’t have made a difference here, but you gotta try everything :slightly_smiling_face:
Well, that only leaves #contactsupport I’m afraid :see_no_evil:
