I’m a very happy new owner of a refurbished FairPhone 4 and I am super stoked in anticipation of using this for at least 5 years into the future. Of course i also purchased a screen protector and case for it to maximize its lifespan, but there is still one thing i would like to do, but don’t know how.
Does anyone know of any automatic way of preventing the phone to be charged all the way up to 100%? If i just could prevent that, maybe let it stop at 90-95%, i believe the battery would have a much longer lifespan. My first thought was some kind of app might do the trick, but any ideas you might have would be very appreciated
I use AccuBattery and I paid for the Pro version,
I use the charging alarm at 80%. You still need to manually disconnect the charger but it helps slow down the battery degradation over time. I’m 16 months in and running at around 80% battery capacity though I haven’t done a full deep discharge/recharge for a couple of months.
Also, there are hardware solutions, like chargie.org, which are controlled by an app on the phone and can stop the current. I used two for some time, until the ROM itself did include it
Some app providers claim that rooting a phone is dangerous. There is ways to hide root from certain apps, and in the most cases this will work just fine.
OT: I personally believe, that I need and should have admin permissions on any device I own, that is capable to differentiate 0 from 1. But this is of course a difficult discussion and every one needs to find an individual answer.
If you do not want to root your phone, the easiest solution is probably AccuBattery and some interactive actions.
I’ve got a couple of smart plugs, Zigbee light switches and HA to run some automations.
If you’re on your home wifi network then it should be easy enough to link the phone battery level with the switch.
Top thinking!
