F-Droid Privileged Extension works on 8.1 and 9 if its built into the
ROM. There were changes (“system as root”) that broke the previous OTA
flash method. @cdesai/@cde made a fixed version that just needs to be
tested before it can be released:
Test binaries are available for download, click “Download test
artifacts” from the button on the right of the topmost build here:
I downloaded the test artifacts ZIP and extracted the file called F-DroidPrivilegedExtension-0.2.8-5-g8d24dbc-debug.zip which I then flashed with TWRP.
Looks like it’s working, fdroid was able to automatically install updates without complaining about unknown sources.
Hmmm, it really didn’t work with latest release? My Nexus 4 running LOS 15.1 (no A/B device, no /system as / AFAIK) does work well, auto-updates an all. FP2 shouldn’t be different,
Actually, I didn’t try the OTA package from the fdroid store.
After the update from 14.1 to 15.1 the priviledge extensions stopped working.
When I went to the fdroid store to install them again I found that note about 8.0 (and not 8.1), so I didn’t install it and asked here instead.
Oreo needs a whitelist permission file (← beware Google link) in /etc/permissions/ for system privileged apps that F-Droid didn’t include until that Oreo update, so you just needed to flash the new update,
