Now running A12 on my FP4. However an app that ran before update, that ran on A12 on my pixel5, no longer works. It’s the Co-op Rewards App, useful cos I get discounts every week and can scan my member card via the app. I’ve tried installing/ uninstalling, no joy!
I open the newly installed app, click “Sign in” then get a red banner across top of screen “something went wrong”.
It must be a problem with A12 on FP4, any thoughts or remedies please…
I would say it’s just bad luck that the app stopped working right after the update. I installed it to try it out got the same result on iodéOS (A13) and a Lenovo Tablet (stock A10). If you press “Register”, you will be forwarded to an error page.
Meinst du die hier > Coop Supercard – Apps bei Google Play ?
Die Kritiken im Play Store sprechen Bände: die App ist Schrott.
Viele Grüße
Thomas
