APN settings for Lebara Germany
Hello everyone,
Since a day, the mobile connection in my Fairphone 4 is unstable. My phone company is Lebara Germany. I have tried to contact them for help but there has been no substantial help on it. Can anyone tell me the full APN settings for Lebara Germany? I am currently based in Darmstadt, Germany and have been using the phone for 2 years with Lebara.
Many thanks in advance.
Best regards,
Ciro.
Und das hier von deren Internetseite hilft auch nicht?
This doesn’t help either?
Für alle diejenigen, die die Internet-Einstellungen selbst einrichten wollen: Gehe in die APN-Einstellungen deines Handys und trage Folgendes ein:
- Name des mobilen Zugangspunktes: internet.lebara.de
**Name**: Lebara Internet
**APN**: internet.lebara.de
**APN-Einstellungen** bei „APN-Protokoll“ und „APN-Roaming Protokoll“ muss „Ipv4/IPv6“ ausgewählt werden.
No not really. It very rarely works and many times it does not. I was wondering I need more detailed APN settings other than just this one.
Then there seems to be a different problem. Can you explain more detailed what
exactly means?
I mean very rarely i see the 4G with exclamation signs vanishes but most of time the exclamation sign exists. As far as my understanding goes, I thought there is a problem with APN settings hence my question. If there is other suggestions, please let me know.
They use the Telefonica Network? i would change from IpV4/Ipv6 to only Ipv4
When they are in the Telefonica Network those are the APN working for me since years with 2 different provider both not O2 directly. Maybe add this APN to see if it helps.
