Perhaps this post explains the root cause of the problem.
Hello, I just see the thread.
I learnt to use it without Play store, with open source Apps on F-Droid (except for Firefox where I had to download its apk file to install it).
I have no problem for now.
Because āFirefoxā is a trademark by Mozilla foundation, the Firefox on FDroid is instead called āFennec F-Droidā ā F-Droid flagged it as āincludes undesirable featuresā so it might not be displayed by default, depending on your preferences (those apps can be hidden) but it can be installed normally and behaves identical to the Mozilla build from what I could tell.
So, Iām the original poster and I wanted to publicize my own feedback.
I have the FP3 for maybe a month now, and itās a almost problem free, full featured, grown up smartphone.
Iāve never owned any smartphone other than thw FP1 and FP2, so I went through the full suffering process. The FP1 was unusable. The FP2 was usable only with severe hacks, and still it didnāt deliver (GPS, battery).
The FP3 just works. Everything is fast enough, the GPS is fast and accurate, battery power is ample, and no annoying software bugs so far.
My only issues are the aforementioned minimal screen brightness and the size.
Otherwise itās a super smooth experience and I love it.
I only received my FP3 a few days ago, almost done transitioning all apps and 2fa from my trusty HTC, all is going well so far,I had one glitch with screen autorotation not working. I toggled the rotate homescreen and it worked again. Others have reported having to reboot.
So far Iām happy with it.
Buying and delivery, smooth. Very happy.
Hardware wise it seems fine, and if it isnāt at least itās repairable.
OS wise Iām happy with Android but understand others may not be.
Software wise Iām happy I no longer have the HTC layer on top of Android.
VoilĆ
So⦠Youāre not able to do calls? Fuck, thatās bad. Coudl they fix it?
@yanone
As for minimal brightness: did you try Red Moon (available on F-Droid)? Iām pleased with it.
Iām quite happy with the phone. No software issues at all (though a friend reports it doesnāt work with his Ford Sync, I really donāt have any Bluetooth connectivity issues)
Iād appreciate a notification led (since thereās a led anyway, for charging) and I find the size a bit much, but Iām totally behind the idea of one phone built to last/repair and I can live with the extra size.
Iād love a protective case which also covers the back (or a different back which is a bit grippier) because I feel like the phone is quite slippery.
I have only minor issues, which do not really affect me. (notify led, hidden WLAN connect, some bluetooth issues with car-audio)
I like the phone very much.
I use it till the initial release. (5 month?)
Iāve got mine since octobre and havenāt had a single issue yet. Just nothing. Itās a huge upgrade compared to the FP2 which was good but had several minor issues in my case.
I was owner of a FP1, now having huge trouble (different problems) with my 4 years old FP2. Therefore thinking about buying the FP3.
You mentionend the ānewā size of the FP3: 15 mm longer than the FP2.
Questions:
Culd you get used to it by now? Or in which cases to you have problems with this aspect? Too large for some bags� I would have problems to get the FP3 into the saddlebag of my bike
Thanks for your feedback!
webaschtl
I am very happy with the FP3 especially after the battery life of the FP2 and frequent restarts, Iāve had my Fp3 2 months and no restarts and no longer have to carry a power pack everywhere. Yes the size is the one downside, I couldnāt say Iām used to it yet, it feels precarious to use one handed as I canāt firmly hold it, it sticks out of jeans pockets and it is too big for the tube bag on my bike.
I thought the FP3 was much bigger than I expected, but after having used it for 3 months, it doesnāt feel that big to me anymore. I have said this before, but as a woman I am used to not being able to carry things in my pocket, unfortunately. None of my previous phones sat comfortably in my jeans pockets and although I have some jeans in which it does work, itās probably a bad idea as carrying a phone in your pocket is a sure way of damaging it anyway. I therefore donāt think being able to fit it in your pockets should be a deal breaker, but of course, different strokes for different folks.
Like I said, I have got completely used to the size and it doesnāt bother me. There are so many upsides, like the amazing battery life, how quick it is compared to my Galaxy S5 and no pangs of guilt every time I read an article about the shady electronics business.
I wouldnāt call FP3 to be big, it is ābig-erā and I like its ābig-nessā. It deters me from carrying it at around with me when not essential, like going shopping or just going out.
You are definitely more aware and present when limited to your own senses.
I really just keep it for work and sometimes use it as music player.
We actually donāt have to carry around phones with us all the time, we used to live without them for so long, then we had huge bricks sagging in our pockets and we even took pride in it⦠but now things have changed again, and they will change again tomorrow, but at what cost that is the real question and real factor.
The size is such an insignificant factor.
Yepp, me!
I had lots of trouble with my FP2 (since 2018) but gave it another chance buying the FP3 in 2/2020 and I can cheeringly say that Iām not encountering a single failure! Everything works, solid, robust phone, very elegant in dark grey, looking classier that the FP2 (which looks a bit cheap and plastic) and the user experience is really good. The weight, the dimensions makes it fun to use, also the buttons and plugs and camera.
I connect it to my fritzbox at home and always have a broad connection.
To me, FP3 is worlds apart FP2.
Also too big to fit into the phone holder on my drone controller
Agreed. Battery life is indeed improved compared to FP2.
I have to update my answer, since I last posted Iāve had three random reboots, the last one just now in the middle of an important phone call, I hope this isnāt going to be like the FP2.
Almost no issues, love it so far. Just has done the not detecting they headphones were taken out thing a couple times. Battery life is great.
Minimum brightness too high but easily fixed with a basic app
Oooh which app so you use to adjust the brightness? I use Bluetooth headphones so no issues there
