Hi, I am struggling with answering calls via network, not WiFi. Wherever I receive a call, it shows as announcement and forces me to unlock my phone before being able to answer it. Do you have any solution for that?
Hi and welcome here.
You can try to install another app to make and receive calls. I’m using one from the Fossify apps. But I use another OS and I’m on FP4 and don’t know if the behaviour is the same.
So this only happens when using mobile data and not when using wlan, i.e. when you use wlan you can answer the call from lockscreen without the need to unlock it first?
Maybe check settings for Phone app, here is my and i don’t have problem (FP5 with stock OS and Phone app)
Thank you all for the help. I checked the setting and somehow I turned off the permission for showing the announcement full size of screen when waken up.
