Hello
after the newest update when going to the updater again.
I got a android.process.media "Der Prozess … wurde beendet.
was bedeutet dieser Fehler?
gruss
vinc
Hello
gruss
vinc
i found out the same error
“der Prozess
android.process.media wurde
beendet”
when starting the Kamera and also starting the Image Gallery
have a nice day
vinc
Go to System Settings > “Apps” > swipe to “All” > scroll to “Gallery” and click “Clear cache”.
Maybe that helps.
If not I guess either something went wrong with your update (you might have to do it again) or an App causes this problem? Did you install a new App recently?
This topic is now unlisted. It will no longer be displayed in any topic lists. The only way to access this topic is via direct link.
