English
Hi there, running FPOOS at the moment, maybe I’ll switch to LOS… I have this question: Will Android for Work (Work Profile) work on LOS? (puh, so much “work”) Root isn’t a problem because I’m the admin myself
Thanks, and merry xmas if you like to…
I’m using the app island, which uses this mechanism, as far as i can tell: https://forum.xda-developers.com/android/apps-games/closed-beta-test-incoming-companion-app-t3366295
Cool, thanks for the fast reply! And the app island sounds also interesting btw.
Yes it does. I have the small work icons for the work apps
Chris
Upgrade to LineageOS went quite smooth, no real troubles since yesterday.
This topic was automatically closed 183 days after the last reply. New replies are no longer allowed.
