Android 6.0: Exclamation mark on Wi-Fi symbol every morning
I think I have found another bug in the Android-6.0-based OS. My Wi-Fi symbol has an exclamation mark on it every morning. And there is a network type indicator („3G“) next to the mobile network symbol, normally, it is only there when the mobile data is used.
When I open the Wi-Fi menu item in the pulldown menu, there is mentioned „no Internet“ next to my Wi-Fi.
The exclamation mark is gone away when I turn off Wi-Fi and turn it right back on.
I did not have the behaviour with Android 5.1, it happened after the update to 6.0.
Do you also have this issue?
  • Yes, I have this issue, too
  • No, I do not have this issue
  • I can not test it
0 voters
This topic will be moved to “Bug Reports” if at least 10 people voted and 50 % can reproduce this problem.
I do not have this issue, but two things would be interesting: Is your phone connected to a charger at night? And does it still have (an) IP address(es) in the morning? (You can check in Settings / Wi-Fi / Advanced.)
Yes.
I don’t know. I will look for it the next time.
I had that bug (?) also with Android 6 and reported that in the Beta section. Trying to quote that here:
Edit: The link doesn’t work.
By the way: I think my phone didn’t get a IPv6 address in my WiFi until I fixed the issue. Might be related, but I didn’t look at it all the time. Maybe you can check that.
OK. In the last days, I had not this problem. But today, it occurred again. I have looked after the IP address, and there stood “Not available” instead of an IP address.
Do you regularly switch off your router or does it run 24/7?
If the latter is the case I’d suggest restarting it to give the dhcp server the chance for a clean startup.
Good luck.
I see exclamation marks on the wifi symbol only when the network address setup routes and all are not completely finished yet. There are different layers in the networking.
So, my wild guess would be that the DHCP lease expires during the night. Of course the phone should renew it automatically, but that might somehow fail.
What is your DHCP lease time? You can check in Checkup / Wi-Fi. It should be several days.
I had a similar problem with ! on my data SIM, which went away after I “reset network settings”. It’s been much better since then (although I have had to set up networks again, of course)
