Android 15 is Now Rolling Out to Fairphone 4! šŸ“² (FP4.QREL.15.14.3.20250923)
As a general rule, it’s always best to apply an update when it’s offered on your device. That’s why we have updates.
However I would advise to always wait for the update to be offered. You can check for updates by going to
Settings > System > System updates > Check for update
If your phone doesn’t see an update, then there’s probably a good reason, and it’s best to be patient. If in doubt, you can check with official Fairphone support, see contactsupport and / or your network operator.
You should install Security patches immediately when available, given Fairphone waits a month or two before releasing them, giving hackers a comfortable head start… Security patches are different from other updates, see my detailed explanation here.
As for the Android 15 (not 14) update, I would wait before getting it, because it has currently two rather nasty bugs: Firstly random reboots, and secondly a Launcher problem specifically for those living or having visited France, the Netherlands and some other European countries. You sound French (ā€œAZERTYā€, ā€œseptembreā€ :wink:), so you would be hit with both barrels…
Unfortunately the November Security patches for the FP4 are inside that buggy A15 update, which means FP4 owners have the choice of either risking an unusable phone, or risking to be shut out of banking and corporate VPNs. What one calls ā€œbeing stuck between a rock and a hard placeā€ā€¦ :frowning_face:
10 posts were split to a new topic: Software Update: FP4 PT32.C.0144
2 posts were merged into an existing topic: Software Update: Android 13 - FP4.TP32.C.0144 - Orange User
Anyone notice problems with voip apps? We have several FP4’s and the one that is on android 15 is having problems with the voip app sounding garbage (constantly interrupted audio) for the first minute of the call
I read somewhere that a user had problems with data connections after the A15 upgrade. Do you use WiFi, or cellular data when calling?
The phone in question that is on android 15 (the other fp4’s are on android 13 still) doesn’t have sim, so can only do wifi.
(none of our other fp4’s on 13 or fp5’s on 15 have this problem. and Our wifi accesspoints are normal high quality unifi ones)
I noticed two changes after the update.
The first is a good one: there was a very annoying bug with the eSIM, which now seems to be vanished.
The second one is a bit odd: My first SIM is only to make phone calls, mobile data is deactivated. But now, the signal strength icon shows an exclamation mark, calls are still possible. It’s a kind of comprehensible, but wasn’t the case for A13.
The exclamation mark is visible if the data of the SIM is turned off by the user in the settings of the SIM.
That’s what I said, but it was not the case in Andoid 13.
Which answer is there for Orange MVNO users? Still A13 here.
To my knowledge the initial Android 15 update (the one this topics is about) was held back for users of Orange. The next update for A15 will include one or more fixes and then Orange users will receive A15, too. But I don’t know a date for that.
Hello It’s 2 December and still no switch to A15. My operator is Proximus (Belgium).@ONDROUS: what about you?
Hey @Ingo , I am using orange network (via hey! telecom). It seems they were bocking the update until I disabled their SIM card temporarily and rechecked for update via WiFi. I think Proximus might be doing same, either slow to deploy or saving money on user support as default Quickstep launcher has known issues after the update..
Dear Fairphone
After installing the A15 update on my F4, the phone call app simply won’t work properly. I have to try three or more times to make a phone call. What could be the issue?
Also, the data connection also seems to have become more unstable after the update.
Best regards, Niels
Welcome to the community forum :slightly_smiling_face:
I’m sorry to hear that you are experiencing issues after the A15 update. You should certainly report those issues to official FP support https://support.fairphone.com
Here this is a community forum where users help eachother , provide advice and discuss. When asking for help it’s always useful to indicate your OS build number and any other information that may be pertinent such as your country and operator.
Have you discussed the call and data problems with your operator?
