Hello.
How can I enter Andi’s (green Android robot) recovery mode screen in FP2 from FP Open? I can only enter TWRP (volume up + power)…
Thanks!
I’m not absolutely sure, but as far as I know, TWRP ist the only recovery of FP Open.
TWRP is a recovery on steroids, more powerful than the stock Android recovery (the Andi’s one). It is included by default on FP Open, replacing the stock one.
What are you trying to do in the recovery mode? I’m pretty sure you can do it with TWRP. I can help you,
I try to go manually back to FP OS from FP Open
Yes! TWRP recovery is more powefull! Finally I stay at Fairphone Open (at least for the moment).
Thanks all!
