Are there technical reasons why the LED on the Fairbuds is on the USB-C port and the USB-C port + LED are on the side instead of the back (USB port) of the hinges?
That kind of thing is absolute rubbish.
The LED should be at the front to see whether charging is taking place etc. The USB port at the back under the hinges.
We are only users like you, so who are you addressing?
And âamateurish designâ, âabsolute rubbishâ is quite rude, are you talking to people in real live the same way? What kind of answer do you expect?
And whats the problem with the position? You can place the box in any position you want, I cant see any difference on which of the identical sides they are. Seeing the LED when plugging the USB cable in, is an advantage in my eyes, instead of plugging in, turning the case and searching for the LED.
So suggestions for improvement are not welcome.
The next model then: Itâs best to place the USB port and adjacent LED at bottom
And say whoever criticizes that:
You can turn the box around when charging.
Again, you are talking to fellow users, we didnât design the case.
And obviously you only want to evaporate a rant instead of making âsuggestions for improvementâ.
Until now I donât even know whats bad about the position. I think itâs quite logical to have input and LED together instead of here and there.
I do not agree with the agressive tone of the original post.
That being said, i would have preferred the charging port and led to have been on the front side.
I now always hold it the wrong way wh n first opening it, even after owning it since it came out.
I think the reason for that is mainly that the charging port is the most obvious landmark for the orientation.
I have the black version so the little gap where you open it does not stand out a lot
