Is there any OS that workes on FP 3+ ?
I would like not to use Android.
There is a widespread interpretation among users that only an Android OS delivered by the smartphone vendor with all the preinstalled Google stuff is βAndroidβ, and everything else is not. While technically many alternative OSes are Android OSes, too, they just come from somebody else and do some things differently than the stock vendor OS.
If you are following the technical interpretation, the #oslist currently gives you the choice to try Ubuntu Touch β¦ and thatβs it. Everything else available currently are different flavours of Android.
