is it possible to completely AirGap a Fairphone (regardless if it is a Fairphone 4 or 5).
The requirement is to at least remove any WiFi / Bluetooth / Cellular module, maybe even remove the speakers and microphones.
Has anybody done it already? Or can someone recommend alternatives?
All basic wireless functions should be on the main SoC to my knowledge. So the best you could do would be to disconnect the antennas. Removing speakers and mics might be somewhat easier, even though I’m not exactly sure how the mics are connected to the rest.
Maybe you could explain in more detail what you’re actually looking for? What would be left after the procedures you seek does not seem like a usable device to me. Maybe you need something in a totally different category.
