Advice for reinstalling OS? [solved]
I’ve been having problems with my FP2 freezing/crashing/restarting for years now. Lots of people seem to have had the same issue since the update to Nougat, and I’ve seen several bugtracker entries with similar symptoms: https://bugtracker.fairphone.com/project/fairphone-android-7/issue/129
The general advice is Factory Reset / re-install OS. I’m keen to try it, but I know it involves connecting the phone to a PC. My FP2 never stays connected to my PC for more than 2 minutes. It has disconnected/reconnected 7 or 8 times while I’ve been typing this.
IF the constant disconnecting is a hardware-related issue, I’m worried that I’ll end up bricking my phone by trying to reinstall the OS. Does anyone have any advice?
Thanks.
The disconnecting issue sounds like a faulty bottom module to me, so exchanging that might solve it.
That’s what I was worried about.
Embarrassingly, I’ve just dug a very short Micro-usb cable out of a drawer… and it seems to connect it the FP2 to the PC without problems. I guess the longer cables I use to charge it are all getting a bit knackered without me realising.
Thanks for your help, Paula. Looks like this isn’t a FP issue!
