I can’t seem to discover how to use accents when using the french language input on my phone. Can anyone help?
Normally if you press and hold the base letter, a popup should appear allowing you to select the accented version you’d want by sliding around (still keeping your finger pressed down). The letter you are on the moment you release is the one appearing.
For instance hold e to input é.
I hope this helps.
Thank you so much! That’s very helpful.
