A question to all Signal (former Redphone) users: Can you place secure calls?
I have a question to all users of the app Signal (former Redphone) who run on Fairphone’s OS (yes, I’m talking to you, @madde :wink:). Can you place secure calls?
I’m asking because, surprise surprise, most of the time I can’t. I have just performed a hard reset, so all installations are fresh - still, about 9 out of 10 times Signal calls won’t work.
When that happens, often the first call is established (the ping sound emerges) but I can’t hear anything (nor the recipient can). In subsequent attempts a strange screen appears, without any information about the recipient:
I’m trying to find out if it’s related to our OS so I can make a better-informed bug report. So please share your experiences with me if you will.
I filed this into the Café category for now, as it is not about Software maintained by Fairphone. If we find out that it is indeed a misbehaviour of Fairphone OS, it will be moved back.
sorry, not using FP OS. Best thing would be to get a debug log and report it on github.
So on which OS is it working then, @madde? Can you confirm that secure calls work on your OS (I presume CM?)
I already did, but I’d like to know whether all (regular) Fairphone users are affected. If so, this would hint at a problem with our OS, wouldn’t it?
I know, mentioning you was meant as an exemption.
I updated from former Redphone App and can place calls as before and it works fine for me. It has, and had before, sometimes difficulties to place a call, depending if the remote does other things on its phone or if it’s idle, probably also on network connectivity between the phones and the server.
Haven’t thoroughly tested it, but so far it seems to work.
It works for me as well! (FP1 with FP OS and signal 3.3.1)
Thanks guys. Yeah, 3.3.1 includes a commit that addresses certain problems with calls. The last times I checked, I could place calls successfully, too. Besides, before that, other devices seem to have been affected as well, not just our favourite gadget.
EDIT: Just now I ran into severe problems again.
so far I have had no problems with both sending text and placing calls.
