English
4G or Dual Sim problem
sim
dualsim
Tags: #<Tag:0x00007fefbaca11b8> #<Tag:0x00007fefbaca1078>
#1
Since the update to Android 7 I haven’t been able to get 4G unless I take out the second sim card.
From the forum I understand that only one sim card can access 4G at a time and the other needs to be set to 2G. But the thing is there is no 2G option, only 3G or 4G.
So I have to choose 4G or Dual sim :confused:
Does anyone have any advice please?
#2
The 4G/3G/2G setting per SIM card can be found under
Settings -> Wireless & networks: More -> Mobile networks -> Preferred network type
German: Einstellungen -> Drahtlos & Netzwerke: Mehr ->Mobilfunknetze -> Bevorzugter Netzwerktyp
French: Paramètres -> Sans fil et réseaux: Plus -> Réseaux mobiles -> Type de réseau préféré
#3
Not on mine!
#4
You could try:
Not ideal, especially if you need to switch often, but might be good for troubleshooting.
#5
I have this same issue, I use a Tele2 (Dutch) SIM in slot 1 and a giffgaff (UK) SIM in slot 2. I would like to have SIM2 set to 2G but I can only choose 4G and 3G like your screenshot.
I have tried a few things including reseting the network settings for both SIM cards. However, simply keeping SIM2 mobile data turned off is my only option for now.
#6
Tele2 does not have a 2G network, that may be where it goes wrong. Though that shouldn’t prevent you from setting giffgaff no 2G.
#7
If I understood you correctly, that’s strange Tele2 not having 2G would cause the other SIM to not let me choose 2G.
#8
Yes that could be a bug in the software as I remember seeing Tele2 users with this problem before.
