Hi Nick, I think itād be worth lodging feedback/complaints with your current provider, if you have the time, but as far as I know, Optus and Vodafone networks both work with the FP5 (for now). I can only vouch for Optus, though.
I can image that, not the way youād want your first experience the FP5 to go.
In summary my response from Telstra was poor, the complaints person I spoke to werenāt looking to change the way the do anything and had no idea if they were evening looking at changing it.
The TIO said they had no control in this situation with what the telcos where doing, but did help getting Telstra to pay me out so to speak.
There is still a case to be made though, the fact is the FP5 does have the technology/ability to work on there network but they are choosing not to test the phone (because they donāt sell it) or change anything on their to fix the situation.
My opinion on this: it allows Optus and Telstra to have a monopoly on the phone market in Australia.
Iāve only tested the FP5 on the Optus network, which works for me, although Iām not happy with the coverage I donāt have much choose.
Yeah I think this is the experience you should expect.
Fundamentally Telstra are not going to unblock FP5 until Fairphone can give them assurance that it works for emergency calling so they can tick the box to say theyāre compliant with the law. TIO canāt/wonāt interfere with something Telstra are doing to be legally compliant.
To Crispyās point about monopoly power, if a handset maker is giving assurance that itās compliant and Telstra are still blocking, then thereās an anticompetitive conduct case to take to the ACCC. But given weāve bought a phone that Fairphone expressly make zero warranties about it working in Australia, weāre not in that scenario.
Itās not going to solve your issue now, but the other thing you can do is put some pressure on the Department for them to implement the vaguely mentioned rumours that they want to facilitate more centralised, systematic testing. This is probably best done via your local MP.
Good day ā¦.
FYI, as of today (01.10.2025) my Fairphone 5 is working with Optus after ~1 week.
Optus may block the FP5 at anytime. So if you go to AUS, get a alternative phone!
Optus may block FP5 but it seems unlikely, at this stage. I wouldnāt be suggesting people get another mobile device unless they wanted to be with another specific provided that doesnāt support FP5 on there network.
So I just arrived in Australia, and so far my FP5 does not connect to anything⦠Am I understanding it right that I need to find a sim on the Optus carrier and itāll work?
Allright, in the event that someone else needs the info:
If the FP5 simply will not connect and you have a physical simcard from another country, remove that sim card.
I have an e-sim from vodaphone aus, and a physical sim from back home, and if the physical sim is in the phone, nothing will connect. Once it is removed, the aus e-sim works just fine
Just wondering but did you try changing the priority of what services would be default for the eSIM vs the physical SIM? Or leaving the physical SIM in the phone but making it inactive?
I did try changing the priority, but when the physical sim was inserted, the phone would not connect to any carrier whatsoever. I did not however try to disable the sim so I canāt say if that would have had an effect.
Geez I wish I had found this thread back in March/April 2025 when I travelled to Australia with my relatively new FP5.
When I first arrived in Sydney my phone was working fine via global roaming. Iām with EE in the UK they roam with the Optus network. But then I noticed it kept getting kicked off and Iād have to restart it to connect again each time.
So I got a local Woolies eSIM (Telstra). And then it didnāt work at all⦠I was livid, and I couldnāt understand wtf was going on. But after reading through this thread (which a complete accident, I came to the forum today to find a solution for a camera problem!! Haha!), I think I understand whatās going.
I was told that because Europe uses 3G network for emergency calling in areas where there is no 4/5G cover that if my device tried to connect to 3G that it would just get blocked each time. This is the 000 issue I assume?? This would explain the challenges with roaming on Optus, but not the complete block with a Telstra network eSIM.
I didnāt realise that Telstra had specifically blocked the FP5!
I assumed I couldnāt get around the 3G emergency calling issue so I borrowed a phone from my mum, transferred the eSIM to that device and tethered it to my FP5 to use the data (so I could still receive WhatsApp calls/messages from my dog minder). It did not occur to me that if I removed my physical EE SIM, and used a different local network eSIM, that I could keep using my phone!
Thanks to everyone here for providing a solution. Hopefully I can use Optus or Vodafone successfully on my next trip back.
Now⦠I better go and see what can be done about this camera
Hey everyone, I have another update (Could be of interest to you @SW1612 )
As suggested by @Sir_Crispy_FP5, I put the SIM back into my phone and deactivated it. The phone then connected to the Vodaphone network with the e-SIM, all good. The good part is, that when I activated my home SIM again, it connected to the Vodaphone network as well and I managed to receive an SMS!
(Not sure if this makes a difference, but I put preferred call, sms, and data on the AUS SIM)
Interested to hear if anyone has, but I think it wouldnāt work.
The only reason FP4/5 arenāt blocked is because there were enough 000 calls on the logs from before the ban was created to show these phones can place 000 calls via native networks and via camp-on.
Models launched after the ban like FP6 will be blocked before they have any opportunity to demonstrate they work. So networks will continue to assume they donāt work. Especially with all the sensitivity in the media about phones and outages causing people not to be able to call 000.
In case it is useful for anybody, FP3 is still working with Optus. I activated a new sim with Optus yesterday (13-Jan-2026) and so far have had no issues. I had to activate the sim āmanuallyā through messaging with an Optus representative / AI Bot, because trying to do it the normal way through optus.com.au/activate didnāt work due to some unexplained ātechnical errorā. I donāt believe this had anything to do with trying to activate the sim on my FP3, but I am not certain.
Hi all - I just started using a friendās old FP3 thatās been gathering dust, because my Samsung S9+ was impacted by the more recent round of 000 issues (all phones with Android 12 or below being blocked, because they wouldnāt default to another network for 000 when Optus was unavailable). Enabling VoLTE on this phone and doing all the system updates means it is working for me, but from what Iāve wasted through on here, it seems like maybe this handset has fallen through the cracks - if itās true I canāt call 000 on VoLTE; can anyone point me at Fairphoneās advice re: emergency calling from FP3? Searching online is mainly⦠returning this thread lol
