3D printing an external battery charger? Then getting it wired!
I’d buy a spare battery for my FP4 if I could charge it externally. To bad we’re such a small market. It might cost as much as the FP4! Maybe there will be one for the FP5 by the time the FP5 gets to the US. Anticipation!!
I was thinking of charging a spare battery while running around with the phone and its battery.
Swapping them in the phone to keep them charged seemed cumbersome.
If you want to charge while running around, why not just use any of the abundantly available power banks? That also spares you the trouble of switching off the phone to change the battery.
If you are using a li-ion / lipo battery, then as spare, then keep in mind it is best to keep the battery around 50%. The spare would not be hot swappable. If that is unreasonable to you, then a powerbank (= a battery pack with standard outputs like USB-A and USB-C to charge another battery) is suffice (with it being charged to about 50%), but it is an extra battery pack in the chain. No matter how you look at it: using a battery (pack) to charge another battery pack is not in the spirit is fairly sustainable. So you might as well go for a quality power bank. Read reviews to see which ones last for a while. Bonus: some cannot quick charge (good for longevity of power bank and smartphone, generates less heat, more safe) while others can charge (certain) laptops as well.
