2. SIM Card Fairphone 4
I have a Fairphone 4.
I would like to use a second telephone number, i.e. a SIM card. Does the Fairphone 4 have a slot for a second physical SIM card? If so, could I also order a SIM card from you?
If not, how can I create/activate a 2nd SIM card as an E-SIM card?
Best regards
Friederike Springer
The Faiprhone 4 has only one physical SIM slot. The second one has to be an eSIM. Ask your provider, whether it is possible and how to change your SIM into an eSIM.
Thank you for the quick answer!
