I have some strange troubles with my WiFi-Connection ! I remenber, there was already a topic about a similar problem but i couldn’t find it…
So here is the case: When I start my FP2 and connect to my WiFi - no problem ! So but if I go out for shopping for example (FP2 loses logically the connection) and come back after a while, my FP2 always remenber the WIFI around the supermarket and doesn’t show my own wifi. OR It shows me my wifi but i can’t connect… I need to restart my FP2 and then it works.
I hope you guys understand it ! It’s a little weird !
My FP2 is up to date.
Any ideas ? Thanks and greetings,
Milo
I know this problem, too. When it happens (like earlier today) I try all of the above and at some stage it works. I have had this happen occasionally over the past 2 or 3 years that I have had my FP2. I suspect that it has to do with software updates. After some updates it keeps happening and after the next it goes away; but might come back again with the subsequent one.
I have the same problem since 1 and a half year, every time I want to connect to internet I must switch on flight mode, I must repeat it every two minutes. It is more than annoying. I hoped the last update would be a solution, but it wasn’t. I hope now to the next update. It is very bothersome.
Same problem with my FP2 too. Generally I restart my phone and it solves the problem, but at the same time it decrease strongly the level of the battery
[Sorry, I reverted this post back into its own topic given this topic isn’t in German. I also removed the language tags here for that reason. – @urs_lesse ]
