Why I’m returning my Fairbuds
I recently bought the Fairbuds for €99 because I strongly support the idea behind them: replaceable batteries, repairable components, and a product designed to last longer than typical true-wireless earbuds.
Unfortunately, after testing them for some days, I’ve decided to return them.
The main issue is the battery reporting. The percentages shown in the Fairbuds app were often delayed or inconsistent. At different points, the app showed values such as 30% and 40%, then suddenly changed both earbuds to 80% without any meaningful charging. In another test, one earbud remained stuck at 30% for a long time while the other continued dropping.
I eventually performed a continuous playback test with ANC enabled. The left earbud stopped after about four hours, even though the app was still showing 20% shortly before it switched off. Four hours is not terrible and would normally be sufficient for much of my daily use, but I also make long Signal calls with my family, sometimes while walking my dog. Calls generally consume more battery, so reliable battery information matters to me.
I also tested the microphone again for about 50 minutes, this time outdoors. Both of my parents could hear me clearly. I specifically asked whether they noticed anything strange about my voice or the audio quality, but they did not. So microphone quality itself has been a positive point.
However, after that test, I tried connecting to the Fairbuds app again and it simply kept showing “Connecting…”. Meanwhile, my Fairphone’s battery indicator showed the earbuds at 30%. At this point, I’m not sure I can trust that number either.
The second major problem was Linux connectivity. I use a ThinkPad running Linux and could not connect the Fairbuds easily or reliably. My Anker headphones and Liberty 4 NC earbuds connect without similar problems, so this was a noticeable regression for my setup.
The third issue was the limited touch-control customization. As a simple example, I frequently listen to German-language podcasts as part of learning the language, and being able to skip back a few seconds to hear a sentence again is important to me. With my current earbuds, I can configure the controls more flexibly.
There were also several positive aspects. I listened to podcasts and music and made several calls, and I found both the audio quality and microphone quality good. The ANC was also adequate for my needs, and I appreciate the repairable design very much.
My current Anker Liberty 4 NC illustrates exactly why repairability matters. After about two years and nine months, their battery life has dropped from more than six hours to less than two. The call quality, ANC, and connectivity remain good, but the batteries cannot be replaced easily, so an otherwise functional product is approaching the end of its useful life.
That is precisely why I wanted the Fairbuds to work for me. I would much rather buy a pair of earbuds whose batteries I can replace after a few years than discard an otherwise perfectly functional product.
But in their current state, I cannot justify spending €99 on earbuds with unreliable battery telemetry, limited controls, and connectivity problems with my laptop, even though I use them mostly with my phone.
One final, smaller disappointment: Fairphone appears no longer to be active on its Mastodon account, and I also do not see Mastodon or the Fediverse mentioned in its marketing emails. I originally discovered Fairphone through several recommendations on the Fediverse, and I have otherwise been a happy Fairphone 5 customer for almost a year and a half.
It would be good to see Fairphone participate more actively in that community again.
I’m sharing all of this not because I dislike the concept behind the Fairbuds, quite the opposite. I hope some of these issues, particularly battery reporting, app reliability, Linux connectivity, and control customization, can be improved in future firmware and app updates. If they were, I would certainly consider trying the Fairbuds again.
The issues you describe seem to be solvable with a software update and not related to physical product quality. That sounds hopeful for others who experience similar issues but can no longer return theirs.
