Just to get this out of the way, I don’t believe in any esoteric BS about electromagnetic fields or something, when I say I can feel it, I mean it physically “tingles”.
@anon9989719, in your experience, what would be the best test setup to measure this?
I have a multimeter with a 22000 count of precision (whatever that means) and I could capture graphs, if that’s necessary.
While the phone is charging, I can feel a “tingling sensation” at various points if I slide around the metal frame with one finger.
I would like to measure that phenomenon, as precise as possible. Certainly it’s unlikely there’s a charge of 24V somewhere, but I can feel it when it’s getting charged and it stops when it’s not, so there has to be a way to reliably measure that.
You have a lot of experience with that stuff, I don’t, that’s why I’m asking you
free-air (i.e. one probe on ground pin of power outlet, the other not connected to anything): 0.25 V AC
phone-ground: 0.33 V AC
body-ground: 0.35 V AC
body-phone: 0.25 V AC (I also measured DC, there’s also nothing there)
The highest number was when I disconnected the charger and measured ground pin in outlet vs. the USB-C cable ground - 30 V AC. But that was when the charger had to be inactive because the PD controller should shut down the circuitry.
@anon73661646 do you use a PD charger, or is it a “dumb” USB charger?
