I’m currently in the process of moving my audio library into hi-resolution / lossless quality and considering purchasing a 256go micro SD card so I can sync my entire itunes library onto my fairphone as well, instead of using my old ipod.
I was trying to check the native specs of the Fairphone’s Digital Audio Converter (DAC) but could not find it anywhere. I assume I might need to purchase an external DAC but i would still like to know the native specs so I can compare (and whether it’s worth it anyway)?
Thanks
