ich überlege, ob ich MicroG nicht doch mal eine Chance geben will und habe dabei gelesen, dass es einen Fork von LineageOS gibt, der quasi alles gleich mitbringt (oder hab ich das falsch verstanden?).
Meine Frage:
Kann ich den Fork einfach mit TWRP über mein bereits installiertes LineageOS drüber flashen ohne alles neu einrichten zu müssen?
Oder ist auch hier ein Factory Reset unausweichlich?
Our ROM and LineageOS use different signing keys, so you can’t flash our ROM on top of the official LineageOS; however, the procedure needed to migrate from the official LineageOS is very simple.
Clean install (wipe data and installed apps)
If you don’t care about losing your current data just reboot into recovery, wipe System, Data, Cache and Dalvik and, without rebooting, install LineageOS for microG.
Dirty install (keep data and installed apps)
If you instead don’t want to lose your current data, you can use our migration ZIP, that replaces the LineageOS’ keys with ours. However, if you have installed unofficial builds of:
F-Droid or F-Droid Privileged Extension
microG's apps (GmsCore, GsfProxy, FakeStore and mapsv1 API)
MozillaNlpBackend
NominatimNlpBackend
you have to uninstall them before the ROM migration. You also have to uninstall the GApps if you have previously installed them.
Finally download the migration ZIP and a build of LineageOS for microG (make sure the ZIP you’re installing is newer than the current installed ROM, if it is not, wait for the next build), reboot in recovery, install the migration ZIP and, without rebooting, install LineageOS for microG.
