I use it for thé french language. Very often i dictated and thé résultats is juste creasy vert far away from m’y original sentence ans un english. Coule it be improuved? Si frustrations because vert convinent when it’s working
The voice recognition depends on the App which you are using. The standard one with normal Fairphone OS (as with standard Android) is probably done by Google. I think there are alternatives, but I don’t know which solution is best for french language.
