I did a Smartphone-Reset and now it works how it should work!
I know that a lot of people had problems with frame drops and the problem with the frame drops also disappeared! Steady 120 Hz, everything runs smooth.
First I advise you to open a ticket with official Fairphone support.
Secondly make sure you have up-to-date backups. As you will have seen by reading above, a factory reset has been successful, but that would delete all your data.
Sending the phone for repair would also lead to deletion.
Thereâs no way of knowing at the moment if any other solution will became available.
For me I had to go to the vibration and haptic detailed settings then changing some settings for it up and down / off and on got it going⌠but it seems pretty weak, the notifications in practice are weaker than the representative short pulse when choosing the strength of the vibration!?
This âfixedâ the problem on my FP5 with Android. I previously had a malfunctioning vibration motor, replacing it did make the phone briefly vibrate on startup, but even the *#*#2886#*#* call app would not work. Checking this Redirect vibration setting and turning it off finally made vibrations work.
