the vibration on my FP3 is not working any more. I even run the service test, so I assume it is broken.
Does someone know which spare part I have to buy to fix this? In the FP Shop ther is no dedicated “Vibrator” spare part.
Rebards,
r.
Rebards,
r.
The vibration motor is in the bottom module:
Hi
If you are out of warranty you can try a clean and DIY effort.
