Vibrating sound
With some phone numbers I receive with my Fairphone 5, after some seconds with normal sound, a kind of vibrating sound. It is very difficult to understand the other party then. The other party can hear me well.
Up to now, this has occurred only with a few phone numbers.
The phone company has sent me a replacement sim card; this however did not change the problem.
Therefore there might be an issue with the FP5 itself.
Does anyone recognize the problem?
Did you try a hardware test of the speakers? Maybe some dirt cause a mechanical vibration, that you can hear through the earpiece.
Does it happen in speaker mode too?
Thanks for answering. The problem existst using earpiece, loud speaker and regular speaker (soft speaker).
I did not try a hardware test, since the phenomenon seems independent from the speaker. Also it occurs with some phone numbers always and others never.
