Vibrate only for calls and messages
I would like to switch via the top drawer between:
  • Sound AND vibration for all calls and messages
  • Vibration ONLNY for all calls and messages (no crescendo for calls, please!)
  • All silent, but no flight mode
Is that possible?
Cheers,
seasack
Did you try to create modes already? There is a quick-settings-tile to enable/disable them.
Alternatively, having set up sound and vibration as your standard option, you can easily switch to “vibration only” by doing the following:
  • press either one of the volume buttons
  • the slider appears with blue speaker button above
  • tap the speaker button and then tap “vibration only” button
    [Edit - or tap “All silent” to silence the phone completely.]
To return to your standard setting just use a volume button again, tap the blue vibration button and then speaker.
As usual when describing UI behaviour, it’s very much more simple than it sounds!
Brilliant! Thank you?!
