I installed no Google-Services (no MicroG or similar)
all data stayed untouched (I did no wiped any cach or partition during installation), except:
homescreen was empty (all symbols have to be re-added, also all widgets)
Google Maps is not working anymore (updated to v. 9.86.1 via Yalp), it starts but after loading the map properly it crashes & closes. In LOS14.1 it worked this way! Why?is now working - after I updated to v. 10.1.0 (in Yalp Store)!
So it was not a problem of missing services, obviously.
Bug of LOS14.1 still there: PIN of SIM2 has to be entered twice (2nd dialogue sometimes just vanishes)
I quit using LOS 15.1 and reverted back to 14.01. I wiped and reinstalled EVERYTHING, Installed LOS14.1 and all my apps worked (Google Maps, Mamikreisel, Kleiderkreisel). Then updated to LOS 15.1. Then the first opening of Google Maps worked, found GPSā¦ When I opened it the second time, it just dumped. Same with the other apps.
I will hope for FP Sibon to release th version with SuperUser and switch to that. Then I will get upates again.
Iām sorry it didnāt work - but I need my phone!!!
I regularly use a Wi-Fi (WPA2-PSK AES-CCMP-128) which has enabled optional PMFs. The FP2 actually uses PMFs and the network performance is good. (Iām on FPOS 18.09.1 (GMS), not Lineage.)
Does your FP2 use PMFs when you set them to optional on the AP?
Sorry to hear that. What setup are you using? Which zips (esp. which gapp packages) did you install on top of lineage? Did you install gapps directly when upgrading? Meaning no intermediate reboot after lineage? You know that you have to flash a new gapps package when upgrading?
Oh by the wayā¦ my issues with low WiFi bandwidth have been resolved after a recent update. I also how have a new router and use 5GHz WiFi on my phone.
One thing I keep running into are random reboots without any proper explanation. Anyone else seeing them?
Another minor thing I encountered with the PAYBACK app, when I wanted to use their PAYBACK Pay service, the app basically told me it detected an unsafe device and denied further usage. My phone is not rooted and even after deactivating Root over ADB I kept getting the same result. No idea what checks the app does, could possibly be that it just blacklists LineageOS or Custom ROMs.
I dont know on what it depends but since a couple of days i have problems with the SD Card. I cant move files from the internal storage to the SD card or even format the SD Card with the FP2. It tooks 5 attempts to copy files from the computer to the sd card (the phone was connected via USB to a linux computer). I dont know if it depends on LOS 15.1.
I had a similar issue fiew years ago. Formatting the sd card solved the problem but that doesnt work this time.
As i said iām not sure if it depends on LOS 15.1. I cant say, if there is a connection to one of the last updates (i installed every update, so now iām on the LOS from 29.10.18).
Even TWRP cant access the SD card when i try to make a backup and save it directly on the sd card.
Two or three years. Its a SanDisk Ultra 64GB.
The cardreader from the laptop hasnt any problems deleting files.
I put another SD card in the phone. It is recognized without problems. When i put the 64GB card in the phone it even didnt get recognized now.
I will format it at the computer now.
I have crashes (i have logcat extreme running now to see where this comes from, so far I have an occasional warning;
w/adreno-EGL(15107): qeglDrvApi_eglGetConfigAttrib:607:EGL_BAD_ATTRIBUTE); very often I experience it in connection with Firefox but other apps like maps and waze are triggering it too. I believe it is something with the memory as frequently triggering screen on/off with apps like ātouch screen protectorā while playing PoGo very often caused crashes too.
I cant shut down the phone with OS options, it keeps restarting instantly; running the shutdown option from automate or through terminal commands does work though. Wrong command linked to the powermenu option?
Updater and devOptions extended reboot options can not open recovery, need to hold vol+ to go there, then the scripts run
Just stumbled over a problem with notifications. Looks like it started with LOS from Oct 29ā¦ Apps that select their notification via the media system (except oif listing notification sounds directly) donāt play a notification irrespectively which one i select. E.g Viber and k9 donāt play any sounds. threema does, for example
@lklaus
Iāve had several warnings in my logcat referencing a change to mediastreams for notifications. Must be a procedure change thats not had its updates come down from every developer.
Seems, that you were right. The card seems to be broken. Isnāt a LOS problem. Tried to format the Card with Windows, Linux, Mac and another android device. Tried different tools like GParted, Partition Wizard, diskpart, Sd Formatter without effort.
I found this information at the SanDisk site.
Write protection errors occur when a flash drive detects a potential fault within itself. The drive will go into write-protected mode to prevent data loss. There is no method to fix this. To verify the issue is related to the flash drive and not your computer we recommend that you try plugging the USB drive into another port on your computer. You should also try the drive on another computer if possible.
Another effect i āsufferā since 2p181021: when on the move with energy saving location mode, the phone does not sleep anymore. So the battery drains quite a lot. Anyone else, or private specialty?
