I just saw that in the changelog there is nothing new for the update today. Does it still make sense to update everytime?
Well spotted ā¦ I just donāt bother to read the changelog .
Cool! I didnāt know that Fairphone published it already on the code.fairphone.com site. Will update the modem.zip now.
Edit: Done! As always, you can get instructions and download links at modemfiles
Good question i was also pondering. Are there really no updates, or are there only no device specific updates, but all other committed LOS changes are included?
On GitHub there are no commits in LineageOSā master branch so I guess there havenāt been anychanges at all.
Question, since I seem to have approached this a little too casually:
The way I read the script the required manual OS file delivers the modem blobs, and the only thing the required OTA file delivers to the process is the META-INF\com\google\android\update-binary.
Now I noticed (i.e. WinMerge says) that the update-binary the (updated) script pulls from Fairphone OS 18.02.0 is different from the update-binary my adaptation pulled from Fairphone Open OS 18.03.1.
Is there a specific reason the update-binary of Fairphone OS is used instead of the update-binary of Fairphone Open OS?
(Hopefully not )
- Encrypted phone
modem-18.03.1.zip (unchanged)
Baseband version: 4437.1-FP2-0-08 (Settings - About phone)
How to make your own modem.zip
Update installed via TWRP 3.2.1-0 (Releases)
lineage-14.1-20180321-nightly-FP2-signed.zip (Changelog)
Security patch level: 05 Mar 2018 (Settings - About phone) - open_gapps-arm-7.1-pico-20180320.zip
The following things work for me so far:
- call / be called
- send SMS / receive SMS
- internet via WiFi
- internet via mobile network
- location
- compass
- screenshot
- main camera (new module)
- selfie camera (new module)
- USB connection to PC / MTP
- alarm (incl. swiping it off)
- MyPhoneExplorer
- root (via already installed addonsu-14.1-arm-signed.zip, not installed again)
- USB OTG
- WiFi hotspot
- Bluetooth (music playback, data connection)
- FM radio
For things that might not work thereās a bugtracker.
- Encrypted phone
lineage-14.1-20180328-nightly-FP2-signed.zip (Changelog)
Security patch level: 05 Mar 2018 (Settings - About phone) - open_gapps-arm-7.1-pico-20180327.zip
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
I updated my FP2 to the actual LOS 14.1, but after the update the display was very dark, hardly to recognice with the setting 'Adaptiv brightness is ON".
I had to set it to āOffā and it is normal again. When I put it back to āONā, it is dark again. Does anybody else have this experience after the update to LOS14.1-20180328? If it is not the update, what else could de the cause for this strange behavier?
Edit: solved
I have adaptive brightness enabled, too, and it works as intended.
Even with adaptive brightness enabled you can still change the overall brightness of the screen, did you accidentally slide the setting to dark?
Itās hard to think itās not the update, when the problem suddenly occurs right after the update. But the same update did not cause this problem on my phone.
So thereās still the brightness sensor.
You could use an App for reading out the sensor (I use Sensors, but thatās from the Play Store) ā¦ What does the brightness sensor say to dark and bright surroundings? An automatically always dark screen should mean the sensor gives a āwow, itās totally dark, we donāt need a bright screenā reading to the system regardless of any brightness around it.
In this case ā¦ The brightness sensor should be the same part as the proximity sensor, this post has some cleaning tips for the area (just expand the āarchived textā bit) ā¦
And it works at my FP2 as well! I just didnāt realise, that I can adjust the brightness as well, when the display is on āautmatic brightness ONā. I must have displaced it myself!
- Encrypted phone
lineage-14.1-20180404-nightly-FP2-signed.zip (Changelog)
ā¦
Attention! This LineageOS build installs an April Fools joke notification you canāt dismiss ā¦ but you can turn it off using TWRPās Terminal.
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
- Encrypted phone
lineage-14.1-20180410-nightly-FP2-signed.zip (Changelog)
ā¦
Attention! This LineageOS build uninstalls the April Fools joke components. -
open_gapps-arm-7.1-pico-20180401.zip (no new build just yet)
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
- Encrypted phone
lineage-14.1-20180418-nightly-FP2-signed.zip (Changelog)
Security patch level: 05 Apr 2018 (Settings - About phone)
ā¦
If your download link starts with lnos1.mirrorhub.io and gives a 404 Not Found, then manually change the start of it to lnos2.mirrorhub.io ā¦ worked for me.
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
How to make your own modem.zip on Windows 10 1709 .
As you can make your own modem.zip with a Linux shell script, hereās how to do it with Windows 10 1709 (Fall Creators Update) ā¦ and of course Iām lazy and didnāt translate the script to Windows PowerShell or something equally demanding, since Microsoft already did something really useful regarding Linux stuff ā¦ although some familiarity with Unix or Linux command line (aka Terminal) basics canāt hurt ā¦
Install the Windows Subsystem for Linux (aka WSL).
Install Ubuntu from the Windows Store.
(Ok, you can choose between some other Linux distributions, too. I chose Ubuntu because itās closest to the Linux Mint I have on dual boot for playing around, and you can easily find lots and lots of helping resources for Ubuntu online). -
Once set up enter the following commands ā¦
sudo apt update
ā¦ I donāt know whether thatās actually necessary for this limited purpose here, but updating the package list canāt hurt.
sudo apt upgrade
ā¦ I donāt know whether thatās actually necessary for this limited purpose here either, but getting this Ubuntu installation up to date canāt hurt.
sudo apt install zip
ā¦ else the modem.zip creator script would complain, and I use unzip from this package further below ā¦ -
wget https://github.com/WeAreFairphone/modem_zip_generator/archive/master.zip
ā¦ Since the script is on GitHub, you could of course employ git to clone it, but Iām not too familiar with that yet, hence the oldschool downloading and the following ā¦ -
unzip master.zip
cd modem_zip_generator-master
ā¦ You should seemodem.sh
(the script file) here now with anls
orls -la
for more info or evendir
if you like. -
At this point, perhaps
modem.sh
may not be up to date, so you could edit in the latest OS version number, download links and checksums at the start of the script ā¦ without continuing the editor war if possible, so for convenienceās sake ā¦
nano modem.sh
ā¦ Right clicking pastes something into the Linux terminal, so you can transfer the links and checksums over from the Fairphone Open OS download page (which is usually faster in publishing new versions compared to the Fairphone OS pages), and donāt forget to change the OS version number in the script,
and Control+O saves the file. -
sudo ./modem.sh
ā¦ This should say āFairphone modem.zip generatorā now and create your new modem.zip in a few minutes. -
Transfer the created modem.zip over to Windows ā¦ C: is mounted on the Linux side as /mnt/c ā¦ so you can copy it to somewhere the currently logged in user of the Windows side would have write permissions, e.g. ā¦
sudo cp modem-18.04.1.zip /mnt/c/Users/yourwindowsusername/Desktop
Done.
By the way ā¦ The Fairphone Open OS 18.04.1 modem blobs are the same as the 18.03.1 ones (says WinMerge), so probably there will be no new modem.zip over here.
- Encrypted phone
lineage-14.1-20180425-nightly-FP2-signed.zip (Changelog)
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
Do we have to update the Google apps with the zip package or do te apps are updated by themselves?
Valid question, please continue reading from here ā¦
- Encrypted phone
lineage-14.1-20180503-nightly-FP2-signed.zip (Changelog)
- call / be called
- internet via WiFi
- location
- compass
- screenshot
- MyPhoneExplorer
- USB OTG
- WiFi hotspot
- FM radio
