I think I made a stupid mistake.
I deleted the app store after doing a FP system update.
I read the forum and wanted to do a back up and relaunch.
But I think I didn’t do the backup approapriatly? I used the app and made a backup from app and data.
Then I switched down the phone and restarted it by pushing the power button and the volume up-button at the same time. Now I have the lying robot on my screen, but in the instructions I see that I needed a zipp-file?
I can’t do anything now, it seems, so hope you can help…
Then, open the Fairphone Updater App and choose Advanced mode -> App Stores and select the Google Store and follow the instructions on the screens. Good Luck!
I did the “Reboot Option” (pfiew, that was easy, thanks!) and now I opened the Updater App.
But I don’t see a Advanced Mode? Only the two options “Cancel” and “Install”.
i find it mildly irritating it is not at all telling you what this is going to install. It’s probably the update for the Fairphone installer. This is a recommended update.
Here is how you find out what version of the installer you have: Go to settings -> Apps -> Choose the “All” Tap -> Scroll to Fairphone Updater and tap. The most recent version is 27 as far as i know)
OT: Yay, a :Koala! How nice! Much more cuddly than a nut.
On topic: I don’t think you would have to do that, but we should be able to find out more about this.
First, did you change the partition layout of your FP manually? That is causing some people a lot of trouble? (If not, did you use the Storage Update to unify partitions?)
Second, are you on WiFi when trying to install the update? (If not: you should be, otherwise it won’t work.)
Just as a precaution:
Just fort the record, the pre-installed “Backup and Restore” app on your Fairphone does not back up all data from your phone. For example, the contents of the “Notebook” app is not backed up, as far as I know. I thus would recommend to use an additional backup solution.
Ah, it’s Kola I’ve been reading Koala the whole time, probably because I think it’s such a nice animal.
But Kola Nut, I mean…
I don’t think I changed the partition layout manually, because I don’t have a clou what that means…
And Storage Update is also an unfamiliar term for me… (I feel a bit stupid, now).
I DO now that I’m on WiFi and I think the backup is not such a problem?
I don’t us so many data. E-mail and calendar are synced with Google, Music is also on my laptop, so I think ony my photo’s are important.
But thank you for the warning, I will make an extra backup just to be sure.
I have 13 GB data, does that mean I have a FP1? :~)
And reinstalling the Google Apps Widget is not an option, because the widget is gone, because I accidently deleted it.
So I think installing manually Kola (Koala :~) ) Nut should be the next step, but I have to wait untill I have enough time (work and a toddler ) to do that with concentration and attention. Maybe during lunch today. Hopefully it will work out.
That means you have one unified storage, so please choose this on the download page: FP1U - Mid-2014 (2nd batch) & FP1 with unified storage. Please remember you an micro SD card in your phone for the update and you need to put the file on the sd card, not the phone storage. When you connect your phone to the PC, you should see both.
