I run FP Open OS since the beginning and OTA updating went smooth as long as I side install the open GAPS and the Xposed framework until 16.10
Now I have upgraded my TWRP 2,8 to 3.0 and now OTA update fails.
- In the updater app download went smooth
- restart to recovery also.
In recovery (TWRP 3.0) it stops. I can restart to system but the update failed. Version is 16.10
Here is the TWRP Log:
__bionic_open_tzdata: couldn’t find any tzdata when looking for localtime!
__bionic_open_tzdata: couldn’t find any tzdata when looking for GMT!
__bionic_open_tzdata: couldn’t find any tzdata when looking for posixrules!
Starting TWRP 3.0.0-0 on Mon Jan 12 06:45:18 1970
(pid 205)
TW_NO_USB_STORAGE := true
I:Found brightness file at '/sys/class/leds/lcd-backlight/brightness’
I:Got max brightness 255 from '/sys/class/leds/lcd-backlight/max_brightness’
I:TWFunc::Set_Brightness: Setting brightness control to 255
I:LANG: en
Starting the UI…fb0 reports (possibly inaccurate):
vi.bits_per_pixel = 32
vi.red.offset = 24 .length = 8
vi.green.offset = 16 .length = 8
vi.blue.offset = 8 .length = 8
setting GGL_PIXEL_FORMAT_RGBX_8888
framebuffer: 3 (1080 x 1920)
Using overlay graphics.
Skipping adf graphics because TW_TARGET_USES_QCOM_BSP := true
Skipping drm graphics – not present in build tree
I:Loading package: splash (/twres/splash.xml)
I:Load XML directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/uk.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/tr.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/sv.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/sl.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/sk.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/ru.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/pt_BR.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/nl.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/hu.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/fr.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/es.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/en.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/languages/de.xml’ directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/splash.xml’ directly
I:Checking resolution…
parsing languageFile
parsing languageFile done
I:Loading resources…
I:Loading variables…
I:Loading mouse cursor…
I:Loading pages…
I:Loading page splash
I:Switching packages (splash)
=> Linking mtab
=> Processing recovery.fstab
I:Processing '/boot’
I:Processing '/system’
I:Processing '/cache’
I:Processing '/data’
I:Processing '/sdcard’
I:Created ‘/sdcard’ folder.
I:Processing '/recovery’
I:Processing '/persist’
I:Created ‘/persist’ folder.
I:Processing '/firmware’
I:Created ‘/firmware’ folder.
I:Created ‘/and-sec’ folder.
I:Creating Android Secure: /sdcard/.android_secure
I:mount -o bind ‘/sdcard/.android_secure’ ‘/and-sec’ process ended with RC=0
I:Backup folder set to '/sdcard/TWRP/BACKUPS/e589b69a’
I:Settings storage is '/sdcard’
Updating partition details…
…done
I:Unmounting main partitions…
Partition Logs:
/boot | /dev/block/mmcblk0p8 | Size: 16MB
Flags: Can_Be_Backed_Up IsPresent Can_Flash_Img
Primary_Block_Device: /dev/block/mmcblk0p8
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Backup_Display_Name: Boot
Storage_Path: /boot
Current_File_System: emmc
Fstab_File_System: emmc
Backup_Method: dd
/system | /dev/block/mmcblk0p13 | Size: 2012MB Used: 498MB Free: 1514MB Backup Size: 498MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI IsPresent
Primary_Block_Device: /dev/block/mmcblk0p13
Display_Name: System
Storage_Name: System
Backup_Path: /system
Backup_Name: system
Backup_Display_Name: System
Storage_Path: /system
Current_File_System: ext4
Fstab_File_System: ext4
Backup_Method: files
/cache | /dev/block/mmcblk0p15 | Size: 629MB Used: 305MB Free: 323MB Backup Size: 305MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent
Primary_Block_Device: /dev/block/mmcblk0p15
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
Backup_Display_Name: Cache
Storage_Path: /cache
/data | /dev/block/mmcblk0p20 | Size: 26095MB Used: 4435MB Free: 21659MB Backup Size: 4435MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent Can_Encrypt_Backup Use_Userdata_Encryption
Primary_Block_Device: /dev/block/mmcblk0p20
Length: -16384
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Backup_Display_Name: Data
Storage_Path: /data
/sdcard | /dev/block/mmcblk1p1 | Size: 29652MB Used: 19202MB Free: 10449MB Backup Size: 0MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI Removable IsPresent Has_Android_Secure Is_Storage
Symlink_Path: /sdcard/.android_secure
Symlink_Mount_Point: /and-sec
Primary_Block_Device: /dev/block/mmcblk1p1
Alternate_Block_Device: /dev/block/mmcblk1
Display_Name: Micro SDcard
Storage_Name: Micro SDcard
Backup_Path: /and-sec
Backup_Name: and-sec
Backup_Display_Name: Android Secure
Storage_Path: /sdcard
Current_File_System: vfat
Fstab_File_System: vfat
MTP_Storage_ID: 65537
/recovery | /dev/block/mmcblk0p16 | Size: 16MB
Flags: IsPresent Can_Flash_Img
Primary_Block_Device: /dev/block/mmcblk0p16
Display_Name: Recovery
Storage_Name: recovery
Backup_Path: /recovery
Backup_Name: recovery
Backup_Display_Name: Recovery
Storage_Path: /recovery
Backup_Method: dd
/persist | /dev/block/mmcblk0p14 | Size: 4MB Used: 4MB Free: 0MB Backup Size: 4MB
Flags: Can_Be_Mounted Can_Be_Wiped IsPresent
Primary_Block_Device: /dev/block/mmcblk0p14
Display_Name: Persist
Storage_Name: Persist
Backup_Path: /persist
Backup_Name: persist
Backup_Display_Name: Persist
Storage_Path: /persist
/firmware | /dev/block/mmcblk0p1 | Size: 63MB Used: 56MB Free: 7MB Backup Size: 56MB
Display_Name: Firmware
Storage_Name: Firmware
Backup_Path: /firmware
Backup_Name: firmware
Backup_Display_Name: Firmware
Storage_Path: /firmware
I:Loading package: TWRP (/script/ui.xml)
I:Load XML directly
I:PageManager::LoadFileToBuffer loading filename: ‘/script/ui.xml’ directly
I:Loading package: TWRP (/sdcard/TWRP/theme/ui.zip)
I:Loading zip theme
I:Loading package: TWRP (/twres/ui.xml)
I:Load XML directly
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/ui.xml’ directly
I:Loading pages…
I:PageManager::LoadFileToBuffer loading filename: ‘/twres/portrait.xml’ directly
I:Loading included resources…
I:Loading included variables…
I:Loading included pages…
I:Loading page main
I:Loading page main2
I:Loading page install
I:Loading page flash_confirm
I:Loading page flash_zip
I:Loading page flash_done
I:Loading page flashimage_confirm
I:Loading page clear_vars
I:Loading page confirm_action
I:Loading page action_page
I:Loading page singleaction_page
I:Loading page action_complete
I:Loading page filecheck
I:Loading page rebootcheck
I:Loading page wipe
I:Loading page advancedwipe
I:Loading page formatdata
I:Loading page formatdata_confirm
I:Loading page checkpartitionlist
I:Loading page partitionoptions
I:Loading page refreshfilesystem
I:Loading page selectfilesystem
I:Loading page backup
I:Loading page backup_options
I:Loading page backupname1
I:Loading page backupname2
I:Loading page backupencryption
I:Loading page backupencryption2
I:Loading page checkbackuppassword
I:Loading page backup_run
I:Loading page restore
I:Loading page restore_read
I:Loading page restore_decrypt
I:Loading page try_restore_decrypt
I:Loading page restore_select
I:Loading page renamebackup
I:Loading page restore_run
I:Loading page mount
I:Loading page usb_mount
I:Loading page usb_umount
I:Loading page system_readonly_check
I:Loading page settings
I:Loading page settings_timezone
I:Loading page settings_screen
I:Loading page settings_vibration
I:Loading page settings_language
I:Loading page partsdcardsel
I:Loading page partsdcardcheck
I:Loading page htcdumlock
I:Loading page lock
I:Loading page filemanagerlist
I:Loading page filemanageroptions
I:Loading page choosedestinationfolder
I:Loading page filemanagerrenamefile
I:Loading page filemanagerrenamefolder
I:Loading page filemanagerchmod
I:Loading page filemanagerconfirm
I:Loading page filemanageraction
I:Loading page decrypt
I:Loading page decrypt_pattern
I:Loading page trydecrypt
I:Loading page terminalcommand
I:Loading page sideload
I:Loading page fixcontexts
I:Loading page installsu
I:Loading page slideout
I:Loading page select_storage
I:Loading page select_language
I:Set page: 'clear_vars’
I:Set page: 'main2’
I:Switching packages (TWRP)
SELinux contexts loaded from /file_contexts
Full SELinux support is present.
I:Not using /misc, not defined in fstab.
I:Got arguments from /cache/recovery/command
Startup Commands: ‘–wipe_cache’I:Inserting ‘wipe cache
’–update_package=/cache/fp_update_.zip’I:Inserting ‘install /cache/fp_update_.zip’
av.offload.enable=true
mm.enable.qcom_parser=37491
mm.enable.smoothstreaming=true
ro.qc.sdk.audio.ssr=false
ro.qc.sdk.audio.fluencetype=none
ro.qc.sdk.camera.facialproc=false
ro.qc.sdk.sensors.gestures=true
ro.qc.sdk.gestures.camera=false
ro.sf.lcd_density=480
ro.adb.secure=1
ro.com.google.clientidbase=android-fairphone
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.nfc.port=I2C
ro.boot.emmc=true
ro.boot.baseband=msm
ro.boot.hardware=qcom
ro.boot.serialno=e589b69a
ro.boot.bootdevice=msm_sdcc.1
ro.data.large_tcp_window_size=true
ro.hdmi.enable=true
ro.hwui.path_cache_size=32
ro.hwui.layer_cache_size=48
ro.hwui.texture_cache_size=72
ro.hwui.gradient_cache_size=1
ro.hwui.r_buffer_cache_size=8
ro.hwui.drop_shadow_cache_size=6
ro.hwui.text_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
ro.hwui.text_large_cache_height=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.texture_cache_flushrate=0.4
ro.twrp.boot=1
ro.twrp.version=3.0.0-0
ro.wifi.channels=
ro.allow.mock.location=0
ro.board.platform=msm8974
ro.build.id=FP2
ro.build.date=mercredi 9 mars 2016, 00:06:27 (UTC+0100)
ro.build.date.utc=1457478387
ro.build.host=ouinouin-debian
ro.build.tags=test-keys
ro.build.type=userdebug
ro.build.user=root
ro.build.flavor=FP2-userdebug
ro.build.display.id=FP2-userdebug 5.1 FP2 eng.root.20160309.000517 test-keys
ro.build.product=FP2
ro.build.version.sdk=22
ro.build.version.release=5.1
ro.build.version.codename=REL
ro.build.version.incremental=eng.root.20160309.000517
ro.build.version.all_codenames=REL
ro.build.description=FP2-userdebug 5.1 FP2 eng.root.20160309.000517 test-keys
ro.build.fingerprint=Fairphone/FP2/FP2:5.1/FP2/root03090006:userdebug/test-keys
ro.build.characteristics=default
ro.config.ringtone=Fairphone.mp3
ro.config.alarm_alert=Cesium.ogg
ro.config.notification_sound=pixiedust.ogg
ro.dalvik.vm.native.bridge=0
ro.secure=1
ro.vendor.extension_library=libqti-perfd-client.so
ro.zygote=zygote32
ro.carrier=unknown
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.name=FP2
ro.product.board=FP2
ro.product.brand=Fairphone
ro.product.model=FP2
ro.product.device=FP2
ro.product.locale.region=US
ro.product.locale.language=en
ro.product.manufacturer=Fairphone
ro.baseband=msm
ro.bootmode=unknown
ro.hardware=qcom
ro.opengles.version=196608
ro.qualcomm.cabl=1
ro.revision=0
ro.serialno=e589b69a
ro.bluetooth.alwaysbleon=true
ro.telephony.default_network=9
ro.alarm_boot=false
ro.bootloader=unknown
ro.debuggable=1
ro.factorytest=0
ro.use_data_netmgrd=true
dev.pm.dyn_samplingrate=1
mmp.enable.3g2=true
net.bt.name=Android
net.change=net.bt.name
use.voice.path.for.pcm.voip=true
init.svc.adbd=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
init.svc.set_permissive=stopped
qcom.hw.aac.encoder=true
rild.libargs=-d /dev/smd0
rild.libpath=/vendor/lib/libril-qc-qmi-1.so
twrp.crash_counter=0
twrp.action_complete=0
vidc.debug.level=1
audio.offload.buffer.size.kb=32
audio.offload.gapless.enabled=false
debug.sf.hw=1
debug.egl.hw=1
debug.mdpcomp.logs=0
debug.mdpcomp.idletime=9000
debug.mdpcomp.4k2kSplit=1
debug.composition.type=c2d
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.stagefright.enable-http=true
media.stagefright.enable-scan=true
media.stagefright.use-awesome=true
media.stagefright.enable-fma2dp=true
media.stagefright.enable-player=true
media.aac_51_output_enabled=true
dalvik.vm.isa.arm.features=div
dalvik.vm.heapsize=256m
dalvik.vm.lockprof.threshold=500
dalvik.vm.dex2oat-Xms=64m
dalvik.vm.dex2oat-Xmx=512m
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=2m
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.image-dex2oat-Xms=64m
dalvik.vm.image-dex2oat-Xmx=64m
dalvik.vm.heaptargetutilization=0.75
tunnel.audio.encode=false
camera2.portability.force_api=1
persist.cne.feature=1
persist.hwc.mdpcomp.enable=true
persist.sys.usb.config=mtp,adb
persist.sys.wfd.virtual=0
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.whitelist=/system/etc/whitelist_appops.xml
persist.sys.strict_op_enable=false
persist.data.netmgrd.qos.enable=true
persist.demo.hdmirotationlock=false
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
persist.audio.fluence.speaker=true
persist.audio.fluence.voicerec=false
persist.audio.fluence.voicecall=true
persist.debug.wfd.enable=1
persist.radio.multisim.config=dsds
persist.radio.apm_sim_not_pwdn=1
persist.timed.enable=true
persist.speaker.prot.enable=false
persist.fuse_sdcard=true
service.adb.root=1
keyguard.no_require_sim=true
bluetooth.hfp.client=1
fairphone.ota.beta=0
fairphone.ota.time=mercredi 9 mars 2016, 00:06:27 (UTC+0100)
fairphone.ota.device=FP2
fairphone.ota.version.name=Onion
fairphone.ota.version.number=1
fairphone.ota.image_type=FAIRPHONE
fairphone.ota.build_number=1.0
fairphone.ota.android_version=5.1
telephony.lteOnCdmaDevice=1
DEVICE_PROVISIONED=1
I:Copying file /cache/recovery/log to /cache/recovery/last_log
I:Attempt to load settings from settings file…
I:Loading settings from ‘/sdcard/TWRP/.twrps’.
I:Backup folder set to ‘/sdcard/TWRP/BACKUPS/e589b69a’
I:Copying file /etc/recovery.fstab to /cache/recovery/recovery.fstab
I:Version number saved to ‘/cache/recovery/.version’
bionic_open_tzdata: couldn’t find any tzdata when looking for CET-1CEST,M3.5.0,M10.5.0!
I:Translating partition display names
I:TWFunc::Fixup_Time: Pre-fix date and time: 1970-01-12–08-45-20
I:TWFunc::Fixup_Time: Setting time offset from file /sys/class/rtc/rtc0/since_epoch
I:TWFunc::Fixup_Time: will attempt to use the ats files now.
I:TWFunc::Fixup_Time: Setting time offset from file /data/time/ats_13, offset 1485766691000
I:TWFunc::Fixup_Time: Date and time corrected: 2017-02-10–16-43-32
I:Set page: 'action_page’
I:operation_start: 'OpenRecoveryScript’
Führe Recovery-Befehle aus
I:command is: 'wipe’
I:value is: 'cache’
Formatiere Cache mit make_ext4fs…
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 2560
Label:
Blocks: 163840
Block groups: 5
Reserved block group size: 39
Created filesystem with 11/40960 inodes and 5256/163840 blocks
I:Recreating /cache/recovery folder.
I:Version number saved to '/cache/recovery/.version’
I:command is: 'install’
I:value is: '/cache/fp_update.zip’
I:Trying to find zip '/cache/fp_update.zip’ on ‘/sdcard’…
I:Looking for zip at '/fp_update.zip’
I:Looking for zip at '/sdcard/fp_update.zip’
Unable to locate zip file ‘/cache/fp_update_.zip’.
Installiere Zip: %tw_file%
Suche nach MD5-Datei…
MD5-Prüfung übersprungen: keine MD5-Datei gefunden
sysutil: Unable to open ‘/cache/fp_update_.zip’: No such file or directory
’/cache/fp_update_.zip’ kann nicht zugeordnet werden
Fehler beim Installieren von ZIP '/cache/fp_update_.zip’
Skript wurde verarbeitet
I:Set page: 'action_complete’
I:operation_end - status=1
I:Set page: 'main’
I:Set page: 'main2’
I:Enabling MTP during startup
I:Starting MTP
Starting MTP
I:sending message to add 65537 ‘/sdcard’ 'SD-Karte’
I:Message sent, add storage ID: 65537
MTP aktiviert
I:Check_Lifetime_Writes result: '592560’
I:Set page: 'main’
I:Set page: 'main2’
created new mtpserver object
MtpServer::run fd: 18
mtppipe add storage 65537 '/sdcard’
MtpStorage id: 65537 path: /sdcard
I:Set page: 'advanced’
I:Set page: 'confirm_action’
I:Set page: ‘action_page’
